d510addict Posted February 24, 2013 Report Share Posted February 24, 2013 Anyone know a good place to get lines flared in portland? I had mine done at oil filter serviecs but they did a pretty bad job and I have leaks. Quote Link to comment
I'm BLUE Posted February 24, 2013 Report Share Posted February 24, 2013 If you have the receipt call them up , tell them what's going on and take it back. They'll likely work with you if they're a repuatable business. I could understand why you wouldn't want to though :hmm: or.. buy a metric or standard (I'm not sure if there is a cross-over for the year) flare kit , some brake line , nuts , and do it yourself :) Just be easy when flaring on the tools .. takes a couple times to get a feel :) Quote Link to comment
datzenmike Posted February 24, 2013 Report Share Posted February 24, 2013 It will cost no more to buy a kit and do yourself. Plus when you're done you still have the kit and the new knowledge. Brake lines come is pre made lengths. Just measure with a piece of string and get one the same or next up size. Use a baseball bat to make the bends. You can do this. Quote Link to comment
d510addict Posted February 24, 2013 Author Report Share Posted February 24, 2013 problem is each end of that particular tube is different as I couldn't find a T junction that would allow me to keep all my flares the same throughout. It needs to be double flare on the soft line side and bubble flare on the T junction side. Quote Link to comment
datzenmike Posted February 25, 2013 Report Share Posted February 25, 2013 Get a bubble flair and cut one end off and double flair it. BAM!!! 1 Quote Link to comment
d510addict Posted February 25, 2013 Author Report Share Posted February 25, 2013 The shoppe reflared and pressure tested for free for me, now I just need to finish bleeding the lines. Quote Link to comment
