Bagged620bulletside Posted February 21, 2013 Report Share Posted February 21, 2013 Anyone Have wiring diagrams for a 1982 720 Behind the dash? I pulled my dash out to fix all the cracks and i found this seperate loom just cut off with exposed wires everywhere and it was just shoved in the dash. Quote Link to comment
_chiefjt Posted February 21, 2013 Report Share Posted February 21, 2013 I can get you pictures of any wiring diagram you want but what exactly do the wires trace back to? So I know what pictures to pm you. Does your A/C work, radio, etc..... Quote Link to comment
Bagged620bulletside Posted February 21, 2013 Author Report Share Posted February 21, 2013 That is a seperate loom that runs off of the main loom with the white plug under the dash I'll get you more pics tonight. Quote Link to comment
izzo Posted February 21, 2013 Report Share Posted February 21, 2013 I might have one at home too, pm me your email and if i do ill email it. Quote Link to comment
datzenmike Posted February 21, 2013 Report Share Posted February 21, 2013 That's some home made crap added to the illumination control plug? Can you dim your dash lights or do they even work??? The brown wire is likely from the cigar lighter.... does it work??? Quote Link to comment
Bagged620bulletside Posted February 22, 2013 Author Report Share Posted February 22, 2013 That's some home made crap added to the illumination control plug? Can you dim your dash lights or do they even work??? The brown wire is likely from the cigar lighter.... does it work??? Yea the illumination switch works and the cigar lighter works. Here is a better pic of the junk i circled it all in paint. Quote Link to comment
datzenmike Posted February 22, 2013 Report Share Posted February 22, 2013 Yeah I sure know about those blue and white plugs on the left. lol. Well the illumination control is the only 3 wire plug nearby and has Black, Red/Yellow and Red/Blue wires. So the dash lights actually dim when you twist the dimmer??? That plug part of the harness or has it been spliced in??? Quote Link to comment
Bagged620bulletside Posted February 22, 2013 Author Report Share Posted February 22, 2013 Yeah I sure know about those blue and white plugs on the left. lol. Well the illumination control is the only 3 wire plug nearby and has Black, Red/Yellow and Red/Blue wires. So the dash lights actually dim when you twist the dimmer??? That plug part of the harness or has it been spliced in??? Yea they dim kinda they flicker a little but i think that's cause the switch is bad. That plug is part of the harness it doesn't appear to be spliced in. The solid yellow wire is nothing to worry about its a hardwire that the PO had running off of the fuse box to run to the stereo its gone now. There doesn't seem to be any radio wires or harness by the way the PO did it but idk if he just rushed it to get it to work or what. Quote Link to comment
