Brake bleeding secret?
gearhead
Is there some sort of brake bleeding secret to help bleed the brakes on a 74 620?Ive bled the brakes 5-6 times times and still my brakes suck ass.This latest time I even used a vacuum bleeder and it pulled out MASSIVE amounts of air,and still my brakes suck.I just want to be able to lock up all four tires if I panic stop.Right now it seems like I would stop better if I just dragged my boots on the ground.
It has a brand new master cylinder and it doesn't look like anything is leaking,but I still have tons of air in the lines.I'm getting the impression that the brake lines actually go into some alternate universe before coming back to the truck and the alternate universe is full of air because there is no way the lines on the truck could hold that much air.
If I open a bleeder there is fluid there,but still lots of air.If I pump the brakes after 4-5 pumps it firms up.
If I can't get it working right after the next couple tries I'll just go and get new wheel cylinders all around,even though its supposed to have them..
  • Replies 9
Guest 510kamikazifreak
Did you bench bleed the MC?
I did a full fluid flush on my car, but there was still air trapped in the MC itself.
This first and foremost
then bleed the brakes from the furthest point(of the master,usually rr,lr,rf,lf) working towards the closest point
First why are you bleeding them? If something was replaced, go there first and be sure all fittings are tight and not allowing air back in of leaking fluid out.
To bleed the master cylinder get a short length of vinyl tubing and fit over the front bleeder (marked F and located closest to the firewall) and pointing towards the driver's fender. Fill the reservoir and stick the other end into the fluid. Loosen the bleeder and pump brake until no air bubbles come out. Close bleeder and do the rear bleeder (marked R which is to the front) tighten bleeder..
Before bleeding raise each wheel and adjust the drum brake so that the shoes are just dragging when you spin the tire.
The other thing is your method. I have the '73 620 FSM and it says to bleed the rears first then fronts. Generally the one furthest from the master moving closer as you go.
If you have a NLSV (Nissan load sensing valve) in line on the rear brake line...look on the inside if the frame under the pass side seat. (the '74 may have it I don't know) The procedure for bleeding this system is ...
NLSV front bleeder
Both front wheel cylinders
Both rear wheels, left first
NLSV rear bleeder
NLSV center bleeder
Get a proper brake fitting tool.
