Bagged620bulletside Posted February 19, 2013 Report Share Posted February 19, 2013 So I believe i have a issue with my ignition coils. When the truck was running one day i pulled the main wire out of the ign coil that has the red and black leads and the truck stalled out, I plugged it back in a did the same with the ign coil that has the blue and white lead (i believe and it stayed running which lead me to believe that i had a bad Ign coil. well i changed the coil out with a new one and still having the same issue? What else could be wrong with it? Quote Link to comment
MikeRL411 Posted February 19, 2013 Report Share Posted February 19, 2013 What truck? What engine? What ignition, stock or aftermarket? Full disclosure will get results. Quote Link to comment
Sealik Posted February 19, 2013 Report Share Posted February 19, 2013 The red and black wires<coil are for the intake side plugs The other wires/coil are for the exhaust side plugs Hmmmmmm Mikey will explain....... :) Quote Link to comment
datsunaholic Posted February 19, 2013 Report Share Posted February 19, 2013 Coil have power? One coil is on its own fuse. Quote Link to comment
Bagged620bulletside Posted February 19, 2013 Author Report Share Posted February 19, 2013 What truck? What engine? What ignition, stock or aftermarket? Full disclosure will get results. Sorry my bad 1982 datsun 720 Z22s 2.2 stock ignition. Quote Link to comment
Bagged620bulletside Posted February 19, 2013 Author Report Share Posted February 19, 2013 Are there any fuseable links that run up to the second ign coil? Quote Link to comment
