CorAce Posted February 8, 2013 Report Share Posted February 8, 2013 Can any one tell me what the difference in strut mounting height is between the factory 510 top hat and an aftermarket camber plate (say T3)? I think I’m running my illuminas to close the bottom of the stroke. I have them set to the softest setting and it still seams a bit rough. Quote Link to comment
Laecaon Posted February 8, 2013 Report Share Posted February 8, 2013 Really? I put in ZX top hats, (1/2" drop to 510). I have Illuminas. I have stock 510 springs. I find I like 2 or 3 on the settings. Quote Link to comment
CorAce Posted February 8, 2013 Author Report Share Posted February 8, 2013 What is the stock spring rate? I'm running 175lb coil-overs, which I brought down from a 250lb. Maybe I should consider something lighter yet. Quote Link to comment
Laecaon Posted February 8, 2013 Report Share Posted February 8, 2013 Only number I could find, from the510realm, was 87.5. hmm. Quote Link to comment
72dyme Posted July 11, 2013 Report Share Posted July 11, 2013 Hate to bring up a old thread. So if you put a 280zx top hat onto a stock 510 strut. You will get a 1/2 drop just by switching them out? Quote Link to comment
KlassicMotion Posted July 11, 2013 Report Share Posted July 11, 2013 I've never heard that before. I'd like to know the answer too. Quote Link to comment
The Dat-side Posted July 14, 2013 Report Share Posted July 14, 2013 I've heard a 610 or 710 top hat will lower it some. :confused: Quote Link to comment
CorAce Posted July 14, 2013 Author Report Share Posted July 14, 2013 Leacaon is running the ZX top hats in his goon and it will give you another .5 to .75 of an inch more travel but its bigger around than the 510 one and has to be cut down to fit. Quote Link to comment
DISLEXICDIME Posted July 14, 2013 Report Share Posted July 14, 2013 210 top hats will lower you about an inch if i remember right Quote Link to comment
edin Posted July 17, 2013 Report Share Posted July 17, 2013 From a 280zx strut swap thread located here. New information/affirmation of information!!!ZX Top hats vs the 510 Top hats.Rumor: ZX top hats are skinnier than 510 top hats.I have heard this from a few people but always in passing. I set out to find out today.Here are the 2, 510 on the right:For some quick measurements:510:ZX:That would look like 1/2" difference to me! Well maybe not huge, it is something.Now you will need to trim the top hat to fit: Quote Link to comment
KlassicMotion Posted July 17, 2013 Report Share Posted July 17, 2013 ^^Thanks for finding that. It is shorter, but I would question it's strength when your finished trimming off the metal lip that makes them structually sound. Quote Link to comment
CorAce Posted July 18, 2013 Author Report Share Posted July 18, 2013 ^^Thanks for finding that. It is shorter, but I would question it's strength when your finished trimming off the metal lip that makes them structurally sound. If your looking for "structurally sound" you shouldn't be driving a Datsun. ;) 1 Quote Link to comment
KlassicMotion Posted July 18, 2013 Report Share Posted July 18, 2013 If your looking for "structurally sound" you shouldn't be driving a Datsun. ;) I'm guessing your just joking... I have no complaints about the build quality from the factory. They were built inexpensively, but they are durable. Quote Link to comment
CorAce Posted July 18, 2013 Author Report Share Posted July 18, 2013 Of course I'm joking, but lets be honest we're not driving dump trucks here. removing some material from a part that was meant for a much heavier and more powerful car to put on a 510 is a pretty safe bet. I've seen this mod done a lot with no ill affects. Quote Link to comment
KlassicMotion Posted July 18, 2013 Report Share Posted July 18, 2013 Well the fact that you've seen it done with no ill effects is one thing. But from a theory point of veiw, my 510 top hats are 1/8" steel, while my 280zx top hats are smaller 14 gauge. That tells me they are relying more on the stamped lip for structure on the 280zx top hats. I'm not arguing that it won't work. I'm just saying use caution. Quote Link to comment
