Breather hose for 72 1200 A12 Valve cover to air cleaner?
DaBlist
  • Replies 8
Thanks! The # was just the ticket, I order the valve cover breather hose:
www.nissanpartszone.com/parts/nissan-hose~11826-h1000.html $8.34 / 20.15 after shipping
and the PCV hose because mine is old and brittle (and I had my credit card out). Funny but couldn't find them both in the same place:
www.everythingnissan.com/Nissan-Part-Number-11828-H1001-p/11828h1001-.htm $14.88 / $31.06 with shipping
  • 1 month later...
go to the wrecking yards and scavenge some vapor hose off other nissans or whatever you can find then use a nylon 90* fitting to join them together. Vapor lines different than heater hose.....
Oops, saw you already solved this - original always works best anyways if you can.
