Farmer Posted January 31, 2013 Report Share Posted January 31, 2013 If you could, would you lengthen or shorten the width of the rear axle on a 620? Just asking cause im planning for a four link with different axle and since I have to shorten it anyways.... Larry Quote Link to comment
wayno Posted January 31, 2013 Report Share Posted January 31, 2013 Is there a reason you are going with another axle than the H190? The reason I ask is because the H190 fits in many different width rearend housings, the datsun 320 pickup being the narrowest, and the 86 720 being the widest I have measured so far. Quote Link to comment
Laecaon Posted January 31, 2013 Report Share Posted January 31, 2013 Because disc brakes, and LSD. The H190 is a dinosaur, and not much support for it (yes I know of disc brake brackets, but those still cost a fortune) Width, well that depends on the wheels you want to run. I would make it so that the WMS is the same distance to the skin of the bed as the front WMS is to the fender. Allows for running identical offset front and rear easily. Quote Link to comment
