barricade88 Posted January 27, 2013 Report Share Posted January 27, 2013 Please, does anyone have a spare wire system or at least the plastic connectors for a '78 620... Mine doesn't go In all the way so I don't have tail lights.. I got pulled over last night.. Please help. I live in Vancouver, WA.. Quote Link to comment
Aibast Posted January 27, 2013 Report Share Posted January 27, 2013 You have no lights to the rear of the car???? Or just some? Quote Link to comment
barricade88 Posted January 27, 2013 Author Report Share Posted January 27, 2013 My tail lights and instrument lights. And the marker lights in the rear Quote Link to comment
Aibast Posted January 27, 2013 Report Share Posted January 27, 2013 first start with the ground. Do the lights get a good ground? Quote Link to comment
datzenmike Posted January 27, 2013 Report Share Posted January 27, 2013 Please, does anyone have a spare wire system or at least the plastic connectors for a '78 620... Mine doesn't go In all the way so I don't have tail lights.. I got pulled over last night.. Please help. I live in Vancouver, WA.. So is it the switch connector or the wire harness connector that's bad. Take a look in the switch end is oner of the pins bent??? You can remove the light switch by unplugging it, pulling the switch post all the way out. Grip the shaft with pliers so it can't move and push in on the knob and turn to release it. With the knob off it's easy to figure out how to remove it. Quote Link to comment
barricade88 Posted January 28, 2013 Author Report Share Posted January 28, 2013 It was the plastic clip that holds the female clips in. One of the female plugs wasn't clicking and locking in all the way, so I had to find one in a junkyard, it was a bitch to put in but I did it. Now I just need the original 3 position switch instead of the 2 position relay. It makes my lights on all the time unles I unplug the switch. Quote Link to comment
