L20B cam says 'Japan 210'
DatsunHealey
  • Replies 8
"210" is the Nissan Applied Model Code for the 1967 510 Standard. Parts with this code were originally designed for it, but may be used for other models/years too. 210 castings can be machined various ways, and does not necessarily indicate the exact part.
The L20B cam is part number 13001-22000. Same as the 510 SSS twin-carb camshaft. It is 0.413" lift, 248° duration.
No nubs at all on either cam... they would have been helpful for breaking loose the cam bolt. I am installing the 210 head and have been advised to install the U67 cam.  If the same casting number means they are the same cam, then i need not bother... it is possible the U67 head has had a lesser cam installed at some point.
Knowing that they start out with the same casting # and are machined differently, makes all the difference.
With thanks!
