prophet1012 Posted September 14, 2013 Author Report Share Posted September 14, 2013 a pic of the win Quote Link to comment
datsunfreak Posted September 16, 2013 Report Share Posted September 16, 2013 Well done. :thumbup: Quote Link to comment
datsunfreak Posted October 11, 2013 Report Share Posted October 11, 2013 Any updates? Need my fix. B) Quote Link to comment
prophet1012 Posted October 11, 2013 Author Report Share Posted October 11, 2013 only some more rust that needs to be sorted out xD i will try to take some pictures of the b310 with the new grille, today or tomorrow :D I am looking for methods to lower the rear of the b310 so far only cutting the springs seem to be the only option. As i don't know if there are other stiffer compatible rear springs somewhere and can't find someone who sell lowering spring for it :confused: Quote Link to comment
datsunfreak Posted October 11, 2013 Report Share Posted October 11, 2013 so far only cutting the springs seem to be the only option. As i don't know if there are other stiffer compatible rear springs somewhere and can't find someone who sell lowering spring for it :confused: There are lowering springs from King Springs in Australia, and from Pit Road in Japan. Neither easy to get in Malta, though. If you like the ride, and are okay with slightly stiffer, just cut them. If you do it quick and don't heat them up there are really no ill effects. If you want them a lot stiffer, you'll need to measure them and see what other springs are compatible. The standard aftermarket spring diameters are 2.5", 3.5" and 5". I'd bet the 5" is close? If it's close enough to one of those sizes, the sky is the limit. Quote Link to comment
datsunfreak Posted October 11, 2013 Report Share Posted October 11, 2013 King Springs lists 3 different heights for either near stock, slightly low, or really low. http://www.kingsprings.com/catalogue.htm Peddars Springs in Oz also lists performance lowering springs in their catalogue... http://www.pedders.com.au/catalogue/Nissan/Sunny/1979-1981+B310%2C+VB310 1 Quote Link to comment
prophet1012 Posted October 12, 2013 Author Report Share Posted October 12, 2013 Thank you datsun freak, i will take an extensive look at them tonight after work :) Quote Link to comment
prophet1012 Posted October 12, 2013 Author Report Share Posted October 12, 2013 had a close call today...the damn rear left tire exploded while driving :sneaky: Quote Link to comment
prophet1012 Posted October 28, 2013 Author Report Share Posted October 28, 2013 guys i may need your help, i am looking for some good looking rims for my datsun, if you have please post pictures of your preferred alloy rims for a datsun. i found these in malta, buy i am unsure if they look good n my b310 Quote Link to comment
ggzilla Posted October 28, 2013 Report Share Posted October 28, 2013 Those will look great on your B310! Classic looks, modern interpretation Quote Link to comment
prophet1012 Posted October 28, 2013 Author Report Share Posted October 28, 2013 the only draw back is they are 13". I think with a small profile tire such as 50 the wheel cap will be huge. what do you think Quote Link to comment
Spoona_Jay21 Posted October 28, 2013 Report Share Posted October 28, 2013 Dude, do it and slam it. Quote Link to comment
datsunfreak Posted October 28, 2013 Report Share Posted October 28, 2013 the only draw back is they are 13". I think with a small profile tire such as 50 the wheel cap will be huge. That's because the wheel gap will be huge. B) You are better off with a 185/60-13 if you want to go really low, and a 205/60-13 (or 185/70-13) if you want to go sort of low. To lose the unsightly gap you'd have from running a 50-series tire it would have to be crazy low... Quote Link to comment
datsunfreak Posted October 28, 2013 Report Share Posted October 28, 2013 This is about what you'd need to do to make a 50-series look right... :wub: Quote Link to comment
datsunfreak Posted October 28, 2013 Report Share Posted October 28, 2013 60-series, low but not crazy low... Quote Link to comment
prophet1012 Posted October 31, 2013 Author Report Share Posted October 31, 2013 hi guys i am about to order lowering spring for kings springs (for the rear end for sure ince it seems the better option). with regards to the frond end, what do you recommend, coilovers (from T3) or lowering springs? Quote Link to comment
ggzilla Posted October 31, 2013 Report Share Posted October 31, 2013 I recommend cut springs. As long as they are not cut too far they work well. Quote Link to comment
prophet1012 Posted November 2, 2013 Author Report Share Posted November 2, 2013 won't the make he car softer? haha i am no suspension expert xD Do you know the stock spring rating on a b310? on a side note, the grille is onnn!!! lol Quote Link to comment
datsunfreak Posted November 2, 2013 Report Share Posted November 2, 2013 won't the make he car softer? haha i am no suspension expert xD Cutting a long metal rod shorter has never in history made it softer. B) The trick is in how you cut it. If you get it too hot, it looses it's temper and get's softer over time (not immediately). If you make the cuts quickly, and with a tool that doesn't heat it very much, it will actually get stiffer. :thumbup: We use something like this: http://www.harborfreight.com/2-hp-14-inch-heavy-duty-cut-off-saw-91938.html Do you know the stock spring rating on a b310? Hell of soft. :rofl: Probably 80--90 pounds. Quote Link to comment
ggzilla Posted November 2, 2013 Report Share Posted November 2, 2013 If you cut it with a hacksaw, it won't change the spring rate. The stock rate is 90.7 or 92.4 depending on year and equipment. Because the B310 is so light, the springs are light. For a stiff performance ride, go with 175. For dedicated [tarmac] rally some use 250. Of course the rear springs must be modified too so the balance doesn't oversteer. 1 Quote Link to comment
ggzilla Posted November 2, 2013 Report Share Posted November 2, 2013 240Z coils are only 103 pounds/inch. For an on-street B310 i would use 280ZX rear coils which are 126 pounds. For dirt road with potholes I would use the stock springs. Quote Link to comment
prophet1012 Posted November 2, 2013 Author Report Share Posted November 2, 2013 Hell of soft. :rofl: Probably 80--90 pounds. Thanks because i am going a front coilover kit from T3 and lowering springs from king springs for the rear (or just cut the rear springs) and i need to give them spring ratings (since t3 offfer different spring rates). what rate do you recommend? keep in mind i wish my b310 to be good at corners (currently it is like a bus lol) but not too much stiff that it damaged the body or something (if it is possible) Quote Link to comment
prophet1012 Posted November 2, 2013 Author Report Share Posted November 2, 2013 If you cut it with a hacksaw, it won't change the spring rate. The stock rate is 90.7 or 92.4 depending on year and equipment. Because the B310 is so light, the springs are light. For a stiff performance ride, go with 175. For dedicated rally some use 250. Of course the rear springs must be modified too so the balance doesn't oversteer. this may create a problem then, as king springs told me that their springs are 25% stiffer than standard , meaning their springs for the b310 are 112.5. if i am correct i have to ask T3 for coils with roughly 112.5 pound/inch right? Quote Link to comment
ggzilla Posted November 2, 2013 Report Share Posted November 2, 2013 Stiffer springs = rough ride. However if the tarmac is extremely smooth they will allow the car to corner faster. For bumpy roads a softer spring is often faster but requires excellent shocks. A combination of medium springs and stiff anti-sway bars can best for performance street usage. When the car is lowered it results in less suspension travel. Therefore many fit stiff springs to lessen the occurrence of bottoming out. A better solution to bottoming out is to use better-suited bump stops. Do not use poly bushings which are overly harsh. Generally the fronts can be stiffened more than the rears before oversteer sets in. I would think 112 front and stock rear would be OK. Many owners use 150 or 175 on the street but I feel it is overly harsh. Some don't mind the rough ride. After lowering be sure to get the wheels aligned as lowering will change it. A small amount of negative camber will make for faster cornering on smooth tarmac. Quote Link to comment
ggzilla Posted November 2, 2013 Report Share Posted November 2, 2013 Just lowering it will remove the bus-like cornering. Even with stock spring rates. Personally, for a street car what I do is use low-profile tires (which lower the car without reducing suspension travel) and fit stiffer anti-sway bar. It results in go-cart like cornering yet still has a relatively smooth ride. 1 Quote Link to comment
