Prophet1012's 1982 B310 project
First of all i am very gratefull i found this forum (ratsun) adn here in malta there isn't much datsun love...mainly small hondas. Iown a b310, was my dad's. he took care of it, he used it only during weekends and kept it in a garage since when be bought it. however having said that he never actually tried doing somthing extra to make it look  sexier or faster :P . I will suceed him in such matters. I started this topic primarily for the purpose of recieving and giving tips and secondarily as a type of tutorial for fellow b310 owners who like me, own a stock one, which they wish to improve it (at leasts its looks) and don't have a clue were to start.
  • Replies 237
here are some pic of my baby
At the field
557560_10151020192437367_1060087513_n.jp
179952_10151020057612367_1795216535_n.jp
Blackening bumper and grille
319469_10151018862282367_1480214967_n.jp
561174_10151018863392367_1115781452_n.jp
556048_10151018874127367_1263991903_n.jp
A little bit dirty...
When i tried to paint stock rims black
529074_10151002125147367_1854809204_n.jp
Finally my friend's photo edit (don't mind it a lot it was done as a preview for myself)
Photo edit looks nice. That will be a really sweat ride when it is finished. I haven't paid much attention to any B310s yet, but I'll be keeping an eye on this one.
Just contacted ground control for front coilover kit, Their representative told me that will fot on my stock struts. Can anyone confirm?
They fit almost any Datsun, including yours.  :thumbup:
So those weldon coilover kits will fit y original struts, am i right? I must be certain before commiting 250 dollars, being a student and all. Still thanks for the input xD
I need some help (once again), another user on this forum told me that the 1200 strut has a smaller diameter than that of a b310, i also found this "The B310 struts are larger diameter (51 mm versus 45mm) B110 strut housing is 45 mm diameter. The larger B210/B310 unit is 51 mm." On the 1200 forum. Does the mentioned diameter corresponds to internal diameter or eternal diameter of the strut. If is the external diameter the above mentioned weld on kit by ground control should not fit, am i right? If yes what kit should i buy?
51mm should be the internal diameter? I know I measured them at about 53mm on the outside.
If you're worried it's too small, get the 510-specific kit.
Do i need to cut the strut shorter?
If you want to go down more than 1.5-2", then yes.
Or do i just cut the perches and weld the coil-over kit?
For a moderate lowering (see above), do this.
Do not buy a 1200 kit for any 13" wheel B310.
Buy the B210 coilover kit.
Thats a fine idea. Still i prefer the coilover idea, it being seemingly safer, all in one package. Just for reference is it a bad idea to buy the 280zx weld on coilover kits? ( In my opinion they are the best option for b310 owner since their strut diameter) I apologies if i am nuisance, asking so many questons in so much little time xD
I think they are the same but go with the zx coilovers if you know they are the same diameter...
Also to isolate the sleeve on the strut housing use some sort of rubber grommet or electrical tape, really helps with rattling.
What are you refering to?
With regard to the rubber and tape. You advice useing them as a type of spacer right? to remove the possible gap they may be between the strut and sleeve. Thanks for the tip.
This is the conversation i had with a ground control representative
Question:
Can you please check the internal diameter of the sleeves of the following coilover kit? https://technotoytuning.com/nissan/s130/front-ground-control-weld-coilover-kit-datsun-280zx
My strut diameter is 2" or 51mm, do you offer compatible weld on kits for my Datsun b310? The 1200 weldon coil-over kit won't do since the strut diameter of 1200 is 45mm
Reply:
All our sleeves have a 2.06" inside diameter. (about 52mm). For the smaller strut casings, like the 1200, we use steel size down sleeves to go inside the aluminum sleeve.
Our kit will fit your car just fine!
