521 l16 lower heater hose needed
  • Replies 8
FOR 510 but may work for a 521. Cut to fit. (thank you Byron510)
Single pass heater core alternative to OEM hoses for the interior side of heater assembly.
Dayco 86121 (2005 Kia Optima, 1989 Geo Spectrum, 1991 Chec Cavalier) can be utilized for both pieces – in fact you can make two sets out of the one hose!
Mike that is not long enough. Zilla that first 90 turn between the firewall and valve cover I've never seen anyone pull off the generic hose option on a 521. Yeah I could cut a bunch of hoses and make it work but I really want a original one.
In the "How to" section I posted [last year' a replacement for both intake and outlet engine compartment preformed hoses for the 411 heater.  This should also apply to the 410, 520 and 521 heaters hose assemblies.  This posting includes hose and barb fitting part numbers.  Hope it will do you some good.
