What did the NapZ come in?
confusion
  • Replies 9
'81-89 trucks, '80-83 200SX, '86 Pathfinder, and 89-90 Axxess van. '86-older used the 71B transmission, '86.5 and later used the 71C (the same transmission used with the KA), assuming 2WD, though the 4WD transmission front case is the same.
The Z20 also came in a 80-81 510 but didn't use the 71-series transmission.
I'm kind of wondering why folks think they need to switch bellhousings... just use the whole transmission. The ONLY time a swap is needed is if you are trying to put an (old) L-series 71B transmission on a KA, as the NAPS-Z 71B bolts right on. The NAPS-Z 71C and the KA 71C are identical.
There is no way to use your original '73 transmission with a KA, unless it's an automatic.
Im using a 280z 5spd, with the napz bellhouse.
  • 4 years later...
