banzai510(hainz) Posted January 14, 2013 Report Share Posted January 14, 2013 Is this for an electronic dizzy? No, only what I listed above EI dizzy youlll use a MSD Blaster2 or a 78/79 Datsunn coil will work(no Ballasat resisitor.Theres many other but this is what I usually say Quote Link to comment
Nismo1970 Posted January 14, 2013 Author Report Share Posted January 14, 2013 Is this for an electronic dizzy? No, only what I listed above EI dizzy youlll use a MSD Blaster2 or a 78/79 Datsunn coil will work(no Ballasat resisitor.Theres many other but this is what I usually say Thanks. I think I need too take it back to the guy who wired it, cuz I had a 78 620 coil in it, and it melted. :crying: it starrted to squirt oil out. Quote Link to comment
banzai510(hainz) Posted January 15, 2013 Report Share Posted January 15, 2013 A 78 coil should not melt as it can take the full 12-14 volts. Points ignition cant take that a point coil cant take that unless there a ballast reisiter Quote Link to comment
Nismo1970 Posted January 16, 2013 Author Report Share Posted January 16, 2013 ya, thats what ggzilla recommended i get for my EI dizzy. But I just figured it was bad out of the box, and got it replaced, but I also think my cap and rotor is bad so i just ordered those. and i'm waiting for those to test it. Quote Link to comment
ggzilla Posted January 16, 2013 Report Share Posted January 16, 2013 Test it with the cap & rotor you have already. If it works good, keep the new cap & rotor for spares. Cap & rotor can be washed & clean. Unless it is burnt carbon tracks, they do not need to be periodically replaced. Genuine Nissan/Hitachi caps go for decades, cheap american-made ones don't last very long. Quote Link to comment
Nismo1970 Posted January 16, 2013 Author Report Share Posted January 16, 2013 Test it with the cap & rotor you have already. If it works good, keep the new cap & rotor for spares. Cap & rotor can be washed & clean. Unless it is burnt carbon tracks, they do not need to be periodically replaced. Genuine Nissan/Hitachi caps go for decades, cheap american-made ones don't last very long. and you said just clean it with dishsoap n let it dry over night right? I'll try that tonight. Also the new coil isn't throwing a strong spark, i was assuming it was the coil but its new, n now i think its the cap and rotor. Quote Link to comment
ggzilla Posted January 16, 2013 Report Share Posted January 16, 2013 Cap & rotor don't throw a spark. Don't assume anything, test it instead. Quote Link to comment
Nismo1970 Posted January 16, 2013 Author Report Share Posted January 16, 2013 Got it. will do. Quote Link to comment
Nismo1970 Posted January 18, 2013 Author Report Share Posted January 18, 2013 So finally got it started but now its blowing white smoke from the exhast. But thank you everyone for ur help n patients, couldnt have done it without ur help. :) Quote Link to comment
banzai510(hainz) Posted January 18, 2013 Report Share Posted January 18, 2013 If the intake manifold was removed and reinstalled it could be just loose intake exahust bolt sucking in water thru the head holes(passages) Quote Link to comment
racerx Posted January 18, 2013 Report Share Posted January 18, 2013 Maybe it's the cold weather....if the car is warmed up and still smokes and smokes a lot of white smoke at the stop light, then it's beyond the coil. Quote Link to comment
Nismo1970 Posted January 18, 2013 Author Report Share Posted January 18, 2013 No didnt take the intake off. Jus the dizzy cap, and oil cap. Great technique on looking inside the oil cap to see if the lobe is at the 9 o'clock. I saw u suggested it in another thread, saved me a valve cover gasket Quote Link to comment
racerx Posted January 19, 2013 Report Share Posted January 19, 2013 if the valve cover gasket is glued on right to the valve cover then the issue about replacing the gasket should not be an issue. Just this month I must off took off the valve cover like 5 times and my gasket is till good because it's glued to the cover. Quote Link to comment
Rocket Dog Posted April 3, 2013 Report Share Posted April 3, 2013 Anybody have experience with one of these? Quality? Junk? It's on flea bay. http://www.ebay.com/itm/New-4-Cyl-Electronic-Distributor-Replaces-Datsun-Nissan-L16-L18-L20B-Hitachi-/310639169692?pt=Motors_Car_Truck_Parts_Accessories&hash=item485389909c&vxp=mtr Quote Link to comment
racerx Posted April 3, 2013 Report Share Posted April 3, 2013 sounds like a good deal...dist and electronic conversion. Just like pertronx..have you googled reviews on the product? Quote Link to comment
banzai510(hainz) Posted April 3, 2013 Report Share Posted April 3, 2013 Its made in China but you can buy it and give us a review Quote Link to comment
Rocket Dog Posted April 3, 2013 Report Share Posted April 3, 2013 I bought one, not sure if I'm qualified to give a technical review. If my truck catches on fire I'll let you all know. Quote Link to comment
racerx Posted April 5, 2013 Report Share Posted April 5, 2013 I bought one, not sure if I'm qualified to give a technical review. If my truck catches on fire I'll let you all know. of course you are qualified, you bought it..now how was installment, how's the quality, does your truck idle better/smoother..let us know. Because this sounds like a good buy and even thought about it at one time... Quote Link to comment
