Syncro Posted December 18, 2012 Report Share Posted December 18, 2012 So my rx7 is running rich as hell and I have no idea why? Floods out super quick too. It's got new injectors, new fuel filter, and a new fuel regulator. That's it fit the fuel system, it's been shooting flames out the exhaust which would be normal if the flames wern't so big. ever since I've l been around this car it's acted likes this and only gotten progressively worse to the point where it can no longer be driven. The gas is new, and there is switch to turn the fuel pump on and off to keep it from flooding during start up. Any help is appreciated, someone a while back said maybe its the mad sensor or o2 sensor, no idea where either are. Edit: Ditched the efi, gonna be running with a carb, this car is gonna be a DD/toy hate drifting but if the shoe fits wear it. 1 Quote Link to comment
Dat Lurka Posted December 18, 2012 Report Share Posted December 18, 2012 Trade for z car. If the O2 sensor is disconnected or missing the the ecu will run the engine in "safe mode" which is ultra rich. Can't you plug a diagnostic thingy in to the harness? Quote Link to comment
Syncro Posted December 18, 2012 Author Report Share Posted December 18, 2012 can't find anything for it to plug into but I'll look some more. I've already got enough z cars, is an 87 so I'd be surprised if it something to pull codes off of. hopefully its the o2 I'll have to check it out when I get home. Quote Link to comment
72240z Posted December 18, 2012 Report Share Posted December 18, 2012 Dont own a car without an FSMhttp://fc3spro.com/TECH/HOWTO/ERRORCODES/ZENKI/zerror.html 1 Quote Link to comment
Syncro Posted December 18, 2012 Author Report Share Posted December 18, 2012 Dont own a car without an FSM http://fc3spro.com/TECH/HOWTO/ERRORCODES/ZENKI/zerror.html thanks, that should help. Quote Link to comment
Dat Lurka Posted December 19, 2012 Report Share Posted December 19, 2012 RTFM :poke: Quote Link to comment
ArchetypeDatsun Posted December 19, 2012 Report Share Posted December 19, 2012 There are tons of those running around here. :sleep: Quote Link to comment
72240z Posted December 19, 2012 Report Share Posted December 19, 2012 Ya the guy up the block from me has 2. One does nothing but take up a fucking parking space, the other is all smashed up. In my area thats a common theme with them sadly. Quote Link to comment
Dat Lurka Posted December 20, 2012 Report Share Posted December 20, 2012 Not a cheap vehicle to own. Quote Link to comment
Syncro Posted December 20, 2012 Author Report Share Posted December 20, 2012 there terrible on gas and oil but otherwise good, almost like a corner carving hummer. Quote Link to comment
Dat Lurka Posted December 20, 2012 Report Share Posted December 20, 2012 I stopped looking at it when I looked up apex seals. 1 Quote Link to comment
bonvo Posted December 28, 2012 Report Share Posted December 28, 2012 I stopped looking at it when I looked up apex seals. still hasnt stopped me from considering a rotory swap for the 610 my grandma had an fb rx7 and drove it from vacaville to south san fransisco every day for years had over 200k before she got rid of it on its original apex seals and she only got rid of it because it got in a bad wreck he boyfriend had a matching one and that one was around for a few more years after hers died Quote Link to comment
Dat Lurka Posted December 28, 2012 Report Share Posted December 28, 2012 The one I was looking at had low compression between two, sides, of the thingy. I was considering it but the rebuild kits were expensive and I knew if I had a rotary that I'd be rebuild quite often. Quote Link to comment
Syncro Posted March 15, 2013 Author Report Share Posted March 15, 2013 Well the o2 sensor wire was torn apart, car also had a cheap universal o2 sensor on it, anyway I've got the sensor replaced and wire repaired, just waiting to put the intake on today. In the mean time here's a pic of it, its been re-sprayed volvo red and I'm in the process of putting the trim back on. Quote Link to comment
Syncro Posted March 18, 2013 Author Report Share Posted March 18, 2013 well it wasn't the o2 sensor damn it. Quote Link to comment
