67_1600 Posted December 4, 2012 Report Share Posted December 4, 2012 I'm looking for a good single point distributor core that I can have recurved and switch over to Pertronix. I know I could just get an electronic dizzy, but I've used Pertronix in the past on a couple of Datsuns and have been happy with how it's worked. I'd prefer local pick up if possible (I'm a little north of Seattle). Link to comment
Eagle_Adam Posted December 4, 2012 Report Share Posted December 4, 2012 i have one in portland Link to comment
67_1600 Posted December 4, 2012 Author Report Share Posted December 4, 2012 Thanks Adam - the funds have been sent. Link to comment
banzai510(hainz) Posted December 5, 2012 Report Share Posted December 5, 2012 Carter might have one 425 275 7746 txt or Frank in Everett 425 280 4747 txt remeber the L16/L16 SSS was a single point and Pertronix is a drop in. I seen soem single point L18 that was drop in also all the L20s need the ring above the point lobe machined off to work. I also seen one l20 pint dizzy NOT work just for info make sure bushing tight. Link to comment
67_1600 Posted December 6, 2012 Author Report Share Posted December 6, 2012 Thanks Hainz - hopefully the one Adam is sending will work with no mods. Link to comment
deans510 Posted December 6, 2012 Report Share Posted December 6, 2012 I had a dual point dist modified with a Pertronix upgrade by Dave Rebello. So, it can be done. Dean Sherman Link to comment
