Little relay on the pass side under the dash
Bagged620bulletside
  • Replies 7
I had a similar problem with my fuel pump relay. It would start clicking and then the truck would die. I took my old one out and took it apart only to find that the inside looked like someone hit it with a blow torch. When I went to get a replacement, Oreilly no longer stocked it, even though it shows up on their website. I got mine from NAPA for about $75. The most difficult thing about dealing with it is mounting back onto the firewall, best get yourself a right-angle screwdriver.
http://community.ratsun.net/topic/38191-1986-720-fp-relay-wiring/#entry591709
Mine would work for two weeks, go out for a day, work for two weeks. It turned out to be the accessory wire. That relay gets signal from your accessory, alternator, and oil switch. Should you wreck it shuts off, why its clicking like that? Who the fuck knows. I've had 3 720 pickups that clicked like that.
The link I posted was a solution that I did. Cost me all of 4 dollars. Never had an issue with the clicking, or the FP shutting off again.
