CameronT Posted November 22, 2012 Report Share Posted November 22, 2012 Hey there ratsun! Having electrical issues with my 620 l20b my cigarette lighter, and stereo went out on me one day after I messed with the dome light. My dome light wouldn't turn off one day so I pulled the bulb and about 2 months later thought I'd try it again, but to my surprise I saw a lot of sparks, so I pulled it out and tried again (that was a bad idea), now I have no power to the stereo that was installed to the middle console on the floor, and cig lighter. My question for you guys is: are there hidden fuses, or did I mess up the wiring? No fuses are blown on the fuse panel either. Quote Link to comment
MicroMachinery Posted November 22, 2012 Report Share Posted November 22, 2012 Even though it may look like your fuse isn't blown, replace anyway. Also, check the connections at or around the fuse block. Quote Link to comment
DanielC Posted November 22, 2012 Report Share Posted November 22, 2012 How do you know the fuses are good. The glass tube fuses can be bad, and look good. Use a test light to check for power on both ends of the fuse, and into the wire beyond the fuses. Quote Link to comment
Z-train Posted November 22, 2012 Report Share Posted November 22, 2012 Get a can of "De-oxit' and hose the fuse box with it. Quote Link to comment
CameronT Posted November 22, 2012 Author Report Share Posted November 22, 2012 I took an electrical tester to all the fuses and there fine, but the radio is after market I'm sure, and i am not sure how it's wired in... De oxit, is that at any auto store? Quote Link to comment
Z-train Posted November 22, 2012 Report Share Posted November 22, 2012 Good electronics store.Radio Shack a slim possibility. Quote Link to comment
CameronT Posted November 22, 2012 Author Report Share Posted November 22, 2012 Alright thanks for the help too! I appreciate it Quote Link to comment
banzai510(hainz) Posted November 23, 2012 Report Share Posted November 23, 2012 cig lighter fuse is the COMMON fuse on the fuse block. als the door buzzer and dome light. ck again or wire broke that usues the circut Quote Link to comment
