fiveoneoh! Posted November 16, 2012 Report Share Posted November 16, 2012 Anybody have a fuel filler neck.... cant make a left turn without dripping gas.. if anyone has one let me know Link to comment
deans510 Posted November 17, 2012 Report Share Posted November 17, 2012 What part are you looking for, there are 3 parts with the metal one and 2 parts with the rubber one? Link to comment
ggzilla Posted November 17, 2012 Report Share Posted November 17, 2012 969.5 was when SOME fuel parts changed over And if you add wagon vs sedan that's a total is 10 different fillers for 1969-1/2. Link to comment
fiveoneoh! Posted November 18, 2012 Author Report Share Posted November 18, 2012 Its the one piece rubber filler neck Link to comment
ggzilla Posted November 19, 2012 Report Share Posted November 19, 2012 They are all one piece. But different. Got a photo of what you need? Link to comment
yenpit Posted November 19, 2012 Report Share Posted November 19, 2012 The most important part of your 1pc rubber filler tube is the top 8inches or so, where it is attached to the body.........that is the section that you can not replicate! If that top section is good, then buy a good used steel tube (the OTHER style), and then try to save a short 4inch straight section out of the rest of your old rubber tube, to go from the tank to the steel tube. If you can't save a small section, then buy new universal fuel safe hose at Summit Racing/Jegs, or try to find something you can use locally at a NAPA, or a marine/boat parts supplier. Hope that helps! Link to comment
