mantas Posted November 12, 2012 Report Share Posted November 12, 2012 Ok i got all kinds of problems sorted out and drove her to the shop. Kept spitting out of the carb. Long story short it seems to be running on 3 cylinders. #3 the plug is white and the rest of them are filthy black. But the kicker here.....when i unplug #4 wire it makes no difference in the running condition, if i unplug any other wire it changes the tune and sounds like a tractor. Anyone have ideas on whats going on? Btw got new wires and dizzy cap ans rotor. Quote Link to comment
DISLEXICDIME Posted November 12, 2012 Report Share Posted November 12, 2012 plug wires on wrong Quote Link to comment
DISLEXICDIME Posted November 12, 2012 Report Share Posted November 12, 2012 what year 620? Quote Link to comment
datzenmike Posted November 12, 2012 Report Share Posted November 12, 2012 Usually #2 and #3 swapped. Should be 1342 order counter clockwise on cap. Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Its a 73' 620 but the engine i got from a 521 which is supposedly an l18. The head says w53 on there so i'm guessing the seller was right about - its an l18 with an l16 head...lol shows you how little i know about these engines. So is this correct? I hope the picture is easy enough to read, let me know if i should post more. photo by onedolla99cents, on Flickr Quote Link to comment
converted_to_datsun Posted November 12, 2012 Report Share Posted November 12, 2012 Looks wrong to me... This might help http://www.davidcmurphy.com/olddat/html/tech/620L20.htm Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Also, i took off the valve cover and the oil seems to smell like gas a bit. Cranked it by hand and no valves seem to be sticking, the head was definitely rebuilt quite recently because it is very clean. Quote Link to comment
DISLEXICDIME Posted November 12, 2012 Report Share Posted November 12, 2012 cant see what cylinder the wires are going to Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 cant see what cylinder the wires are going to If you look by the cap they are all running to the respective cylinders - top wire runs to #1, then next one to 2 and so on. I don't know if that helps... Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 I see whats going one. May be 1 & 4 are swapped. I didn't mess with the wires but lets see what happens when i swap them around. Going to garage and will report with results, hopefully i don't have to push her off the cliff just yet. Quote Link to comment
converted_to_datsun Posted November 12, 2012 Report Share Posted November 12, 2012 The one closest to the firewall should be one then going clockwise from there 2, 3, 4 Looks like yours are hooked up 4, 3, 1, 2 .... Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Whats the order of the wire lenght? Quote Link to comment
converted_to_datsun Posted November 12, 2012 Report Share Posted November 12, 2012 All I can tell my wires have numbers marked on them for which cylinder... Probably 4 would be the longest but that's as far as I know Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Well i tried 1342 and didn't start. Went back to 1234 and it stars back up. I looked at the firing order for the earlier l16/l18 engines on google and it seems that my order was correct? How will wire lenghts affect the firing order? I mixed it all up but she stars again with the old set up. Quote Link to comment
DISLEXICDIME Posted November 12, 2012 Report Share Posted November 12, 2012 did you try what datsun mike suggested? Quote Link to comment
DISLEXICDIME Posted November 12, 2012 Report Share Posted November 12, 2012 i would try 2431 some one might have put the distributor 180 out Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 I tried what mike suggested, no bueno. I'll try 1243 when i get back from getting a beer HAHA. Long day and no progress, at least i figured out what was causing my fuse to go out, turns out someone left a wire against the dash for it to ground out. Now i have tail lights! YAY! Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Well none of the combos suggested worked. So i went back to what i had 1234 clockwise and she runs, and runs better with the new plugs. Now when i changed out the plugs it seems like all of them were filthy so may be something is fucked up with the wires? Do wire lenghts matter? I mean i went off my best judgement and plugged in the furthest wire to the furthest plug and so on.... Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Btw she is definitely running pig rich because the plugs are black and covered in fuel. Quote Link to comment
Laecaon Posted November 12, 2012 Report Share Posted November 12, 2012 But really, you have the wires wrong. 1234 is not the proper firing order, and impossible for the cam and crank to allow that for all the cylinders to fire correctly. 1342 is correct(and always will be on datsun L series 4 cylinders), that is if you put your 1 in the correct spot. Wire length means nothing. FYI, we are talking at the cap, not at the plugs. And black plugs? matte black, or glossy black? Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Plugs are glossy black. Well i just put them back to what they were originally. I will try 1342 again tomorrow. Plugs definitely have fuel on them. Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Oh and it is 1342 actually. On the distributor i was reading clockwise - idiot! I dont know how to read backwards haahah. Anyways cylinder one is closest to the firewall or to front of car? I cant wrap that one around my head from the shitty charts ive seen. Quote Link to comment
Laecaon Posted November 12, 2012 Report Share Posted November 12, 2012 Really depends. Best to put the motor to TDC (with being able to see the cam lobes at 10 and 2 through the oil cap hole), and whereever the rotor points should be where plug number 1 is. Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Really depends. Best to put the motor to TDC (with being able to see the cam lobes at 10 and 2 through the oil cap hole), and whereever the rotor points should be where plug number 1 is. Now we are talking, ok i'll give that a go tomorrow. The thing that sucks, i just put the valve cover back on.... Quote Link to comment
mantas Posted November 12, 2012 Author Report Share Posted November 12, 2012 Well i went around to confirm the casting numbers basically the block is L18 and the head is W53, so does that mean the idiot i bought this from slapped an EFI head on there? And i have a 32/36 DGAV Webber on there. Going to get a wideband sensor for this thing because I have never tuned a carb by ear. Good idea? Quote Link to comment
