terolla Posted October 28, 2012 Report Share Posted October 28, 2012 quick question, is the rear track width of a factory s30 the same as a factory 510? just asking since i know some parts can be used on either chassis. Quote Link to comment
datzenmike Posted October 28, 2012 Report Share Posted October 28, 2012 Rear tread width... that's center line to center line between the two rear tires on a 510 is 50" The S30 is 53 at the back. This does not take into account the rim off set. (if any) Quote Link to comment
ggzilla Posted October 28, 2012 Report Share Posted October 28, 2012 510 track width: 50.0" front, 50.0" rear S30 track width: 53" front, 53" rear Track width -- for those who don't know -- is center-to-center width of the tires. So it depends on using wheels with the stock offset. The brake to brake width is different (width of the axle assembly is not the same as track width). Quote Link to comment
thisismatt Posted October 28, 2012 Report Share Posted October 28, 2012 errm, which parts can be used on a 510? S30 IRS is of a different design. S130 on the other hand is same style IRS. I would compare WMS (wheel mounting surface) to WMS when comparing designs... Quote Link to comment
datzenmike Posted October 28, 2012 Report Share Posted October 28, 2012 The finned rear brake drums will swap.... :) Quote Link to comment
