Looking for a 620 Tachometer or tips to mount an universal one
  • Replies 4
Doubtful, the Z cars are all 6 cylinder. We used to just attach the after market tach to the steering column with a large gear clamp. There is a blank covering the hole where the stock 620 tach or clock option should go. Almost any tach should look ok there.
Ive got a inexpensive aftermarket tach already mounted in the stock 620 tach delete plate ready to be bolted into a 620 dash. I also wired it to plug into the stock harness connector on the the trucks that are wired for a tach/clock.
PM if interested and i will get some pics taken of it.
