NEED a pai of koito headlamps!!
  • Replies 13
Well I just bought and installed a set of Koito amber fog/high beams and I want all the headlamps to match. So for now I took the original Koito high beams (clear) and put them in the position of the standard headlamp and put the Koito amber fogs in the high beam spot. But I cant run high beams as standard driving lights, soooooooooooo I would like to keep them OE.
It may be difficult to find the Koito three prong headlights. They are the high/low beam combination, and most of the time the low beam part is on, and that is the part that burns out, just because of the time the headlight has been on, A 40 year old truck has had a lot of time for the headlights to be on. And if you do get some that work currently, they may burn out soon.
are you talking about the sealed beam type? Would offer to send you one from England but the dip pattern will be the wrong side.
Ya, sealed beam type. Three prong on the back. No go? Damn it..... I've got ONE! Just need one more.
