bass Posted September 18, 2012 Report Share Posted September 18, 2012 i just installed 31x10.5 15" mud tires on my 1972 620, and there is minimal clearance from tire - quarter panel, my leaf springs only have two leaves per side, i think the last guy took a leaf out cuz it was lowered on 2" blocks should i get a new or used set with 3 leaves? or has anyone have experience with add a leaf? jc whitney sells some for pretty cheap that say they lift the truck a couple inches, im not looking for a lot of lift, just enough to clear the tires and room for flex without rubbing, i dont realy want to locate springs on top of axle because i dont really want to mess with lifting the front more than tosion arms allow. truck looks pretty tough with the mudders. thanks bass Quote Link to comment
datzenmike Posted September 18, 2012 Report Share Posted September 18, 2012 Do a 4" body lift. Well, that, and some extra springs added. Quote Link to comment
]2eDeYe Posted September 18, 2012 Report Share Posted September 18, 2012 Do a 4" body lift. Well, that, and some extra springs added. :sick: I would look into gettting another set of stock rear springs. If you are able to do a small bit of fab you could run longer springs for a more supple suspension. If you need lift you can move the axle under the springs and get about 5-6" Let's see some pics :thumbup: Quote Link to comment
datzenmike Posted September 18, 2012 Report Share Posted September 18, 2012 2eDeYe' timestamp='1347977339' post='759377'] :sick: Wat??? Yes the frame kind of sticks out but it's cheap and not rocket science to do.... ok 3" My 620 has about 16" of lift above stock. Quote Link to comment
]2eDeYe Posted September 19, 2012 Report Share Posted September 19, 2012 I like rocket science. :lol: Quote Link to comment
