greasegorilla57 Posted June 2, 2008 Report Share Posted June 2, 2008 so i have recently bought my first datsun. of course not running when i bought but i knew she had potential. the guy i bought it from said it blew a head gasket and he tried to fix it along with a new timing chain. after getting it home i found that the timing chain was put on horribly wrong. after watching hainzs video i put the new timing chain on the right way and a new head gasket, i got it all back together. it is super close to sarting it will catch and catch just not enough to start. the truck was sitting for a year before i got it. my compression tester is saying 75-80 is that alright? i'm going to get some new points for it tomorrow to see if that is the problem. but i have spark and i can't really put the timing light on it till i have it running? does any one have any other suggestions? Quote Link to comment
fiveNdime Posted June 2, 2008 Report Share Posted June 2, 2008 Do you know how to static time?? Thats what I always do when I build motors. Quote Link to comment
datzenmike Posted June 2, 2008 Report Share Posted June 2, 2008 75-80 is not alright. Way too low. Check the valve clearances and hope they are too tight and thats your problem. Re-check the torque on the head gasket too. If the rings are shot, this also would cause poor compression. Squirt some oil in the cylinder, if compression goes up, the rings are bad. If the cam was WAY wrong the pistons could have come up when open and bent some.:eek: Quote Link to comment
banzai510(hainz) Posted June 2, 2008 Report Share Posted June 2, 2008 Do as Mike said and ck the valve clearance. you sure the dizzy was lined up correctly? ck the ON wht/blk wire and the HOt START wire and make sure you have the 12volts there. meaning car will run in START but dies whn key snaps back to the ON position. so ck the wire to the ballast resisitor also in diagram Quote Link to comment
racerx Posted June 4, 2008 Report Share Posted June 4, 2008 75-80 is not alright. Way too low. Check the valve clearances and hope they are too tight and thats your problem. Re-check the torque on the head gasket too. If the rings are shot, this also would cause poor compression. Squirt some oil in the cylinder, if compression goes up, the rings are bad. If the cam was WAY wrong the pistons could have come up when open and bent some.:eek: Also put a lot oil around valves and rockers and springs...when cars have not been running for a long time, there miay not be enough oil or it may be bad. if you do not have an pressure gauge do so now. You can temp. install one where the sending unit is located. Then have someone start it and watch the gauge. If no oil pressure after start turn off engine.... Quote Link to comment
greasegorilla57 Posted June 24, 2008 Author Report Share Posted June 24, 2008 racer x ya I put some heavier oil over the valves and the compression in the cylinders have gone up to around 95-110. the problem seems to be that i'm getting spark at the distributer but not at the plugs but how ever i can start the truck and barely keep it running(running horribly by the way) so.... Quote Link to comment
banzai510(hainz) Posted June 24, 2008 Report Share Posted June 24, 2008 oxymoron statment!!!!! that i'm getting spark at the distributer but not at the plugs but how ever i can start the truck and barely keep it running(running horribly by the way) so.... If no sparks at plugs how is it running. PS you sure the oil pump spindal/drive is installed correctly? when it was at TDC? rorot points at #1 plug wire and your timming plate is close to the center? If timming plate or dist is pused to one side of the timming plate to get running then you might be off a tooth. try removng the 100mm bolt that holds down the distributor and move the dist abit more and see if runs better. your close!!!!!!!! amke sure dizzy at TDC 0 on crank looks like this should I assume the vlave lash is correct ans the timming chain is timmed? Quote Link to comment
