Meticulous Posted August 15, 2012 Report Share Posted August 15, 2012 So i have a 81 210 with a stock carb and im stepping up to the weber, any close up pics of an A15 with a weber would be helpful and also any advise or knowledge of this swap would be appreciated thanks again guys. joey Quote Link to comment
datsundash Posted August 15, 2012 Report Share Posted August 15, 2012 Unbolt old carb, bolt on new one, hook up fuel lines, and choke, linkage. Drive. Quote Link to comment
Eagle_Adam Posted August 15, 2012 Report Share Posted August 15, 2012 just like that ^^^ Quote Link to comment
Meticulous Posted August 15, 2012 Author Report Share Posted August 15, 2012 what about all the lines that go to the stock air cleaner cover, does anything need plugged and what not is what im asking i guess. Quote Link to comment
Eagle_Adam Posted August 15, 2012 Report Share Posted August 15, 2012 you wont use the sock air cleaner any more Quote Link to comment
Meticulous Posted August 15, 2012 Author Report Share Posted August 15, 2012 what about this stuffand exhaust comes out these, i understand i wont use the stock aircleaner there is just alot more to it the throwing on the carb. Quote Link to comment
datzenmike Posted August 15, 2012 Report Share Posted August 15, 2012 First of all you're getting a new direct replacement carb from Redline?. It will have all the necessary adapter plates and parts including, (I think) a Weber air filter. All those hoses can be chucked if you are not keeping the air pump. Seal off where the exhaust leaks out. Quote Link to comment
Dguy210 Posted August 15, 2012 Report Share Posted August 15, 2012 Pretty easy swap, I did have to remove the EGR on the intake manifold to get the Weber to clear, yours may clear without removal depending on the adapter though. I believe in an early post you had already removed it to show a caked up passage, so just block that off. Quote Link to comment
Meticulous Posted August 15, 2012 Author Report Share Posted August 15, 2012 yes its a replacement from redline, i get the new carb tomorrow so im just preping everything for a nice install, ill post some pics of the new setup. thanks guys Quote Link to comment
Meticulous Posted August 15, 2012 Author Report Share Posted August 15, 2012 Pretty easy swap, I did have to remove the EGR on the intake manifold to get the Weber to clear, yours may clear without removal depending on the adapter though. I believe in an early post you had already removed it to show a caked up passage, so just block that off. sweet thanks man!! hope it comes with the plate..if not i can make one up. Quote Link to comment
datzenmike Posted August 15, 2012 Report Share Posted August 15, 2012 Just clean and plug the EGR hole on the intake with JB weld. Quote Link to comment
Meticulous Posted August 16, 2012 Author Report Share Posted August 16, 2012 Just clean and plug the EGR hole on the intake with JB weld. good idea i was thinkin to myself man it would look tacky with just a plate. it might be ratty but i still like things to look clean! Quote Link to comment
datzenmike Posted August 16, 2012 Report Share Posted August 16, 2012 Use a paint scraper to trowel it in flat. Sand down if needed. Because JB flows a bit before hardening you may have to use two coats to fully fill the hole. Then grind down flush and/or sand it smooth. 1 Quote Link to comment
Meticulous Posted August 17, 2012 Author Report Share Posted August 17, 2012 this is what i have so far Quote Link to comment
Meticulous Posted August 17, 2012 Author Report Share Posted August 17, 2012 how do i post large pics, im using photobucket? Quote Link to comment
DatWifey Posted August 17, 2012 Report Share Posted August 17, 2012 When you're looking at your album of photos, just hover of the thumbnail and when the drop down appears, click on the IMG code box. It will auto copy for you, and then just paste here. Quote Link to comment
Meticulous Posted August 17, 2012 Author Report Share Posted August 17, 2012 thnx Quote Link to comment
Dguy210 Posted August 17, 2012 Report Share Posted August 17, 2012 this is what i have so far Looks good :thumbup: Quote Link to comment
Eagle_Adam Posted August 17, 2012 Report Share Posted August 17, 2012 gotta love a weber! Quote Link to comment
BigBopper805 Posted August 26, 2012 Report Share Posted August 26, 2012 thats what i have in my L16 ! but im trying to add some more horsepower any suggestions?? Quote Link to comment
BigBopper805 Posted August 26, 2012 Report Share Posted August 26, 2012 oh shit it worked!! thank for the IMG advice lol no i can post pics!!!!! :thumbup: Quote Link to comment
71kat510 Posted October 11, 2012 Report Share Posted October 11, 2012 what carb would i need for my l18 its pretty slow needs some freshing up Quote Link to comment
