No Spark from Coil
  • Replies 6
With key on, get a short jumper wire and touch the -(neg) side of the coil to ground several times. You should have spark.
Yes sparks...
Points are closed and not opening
Points are open but not closing
Dizzy loose or not properly grounded.
Wire between dizzy and neg side of coil missing, loose, wired wrong.
No spark the coil is bad.
This is the Unilite you got from Carter?
Maybe the module broke already?
You can put the old point dizzy back in and hook up 1 wire to it ans see if it woorks.
at ballast you should get close to 12volts and at coil about half that, like 6 volts (not running) higher running .
ck the module to see if cracked or rubbing on soemthing. I believe you can get new modules.$$$$$$$$$
You won't get any spark if the engine is stopped with the points closed. If you remove the cap you can watch the points or force them open. Then you will get one fair spark from this method. But probably not sparks. With the matchbox certainly not.
