project620 Posted May 16, 2008 Report Share Posted May 16, 2008 i have read that that is one of the first things that give out and if left unrepair it could damage the head. i havent engine swapped my truck yet but should i replace the tensioner while it is out or just put it in like that????:confused: Quote Link to comment
nismopu Posted May 16, 2008 Report Share Posted May 16, 2008 its not the tensioner itself but mostly the plastic guides that break and cause excessive slack. In some cases I have seen the tensioner bolt itself come loose and cause the chain to skip. So, just remove the valve cover and see if the plastic guide is still there, it it isn't then replace the whole timing set. peace. Quote Link to comment
kiznook Posted May 16, 2008 Report Share Posted May 16, 2008 its not so much the tensioner as it is the guide rails. Your best bet is to get a timing kit, this way you can replace it all (gears, chain tensioner, guides) Quote Link to comment
project620 Posted May 16, 2008 Author Report Share Posted May 16, 2008 ok den i will check it out. Quote Link to comment
hang_510 Posted May 16, 2008 Report Share Posted May 16, 2008 have bought anything here but found this yesterday... http://www.store.partsdinosaur.com/product864.html Quote Link to comment
kiznook Posted May 16, 2008 Report Share Posted May 16, 2008 There was a set just like that up on egay. Looks like someone obought it, but it was only $53 with shipping. Same brand chain and i think the tensioner was the same too. EBAY SET Quote Link to comment
project620 Posted May 17, 2008 Author Report Share Posted May 17, 2008 does anyone have a pic of wat it SHOULD look like??? Quote Link to comment
datzenmike Posted May 19, 2008 Report Share Posted May 19, 2008 Thanks Kiz. Just enlarge it. http://cgi.ebay.com/ebaymotors/1989-1997-Nissan-Pickup-Frontier-240SX-KA24E-Timing-Kit_W0QQcmdZViewItemQQcategoryZ33625QQihZ013QQitemZ230252382440QQrdZ1QQsspagenameZWDVW Quote Link to comment
kiznook Posted May 19, 2008 Report Share Posted May 19, 2008 This pic will probably only last as long as the auction. Quote Link to comment
datzenmike Posted May 19, 2008 Report Share Posted May 19, 2008 What's up with Nissan switching to a crappy single chain when they got years of good service from the old tried and true double??? Cheapness I guess. Did you know Henry Ford went around to wrecking yards? He would ask the owners what parts they didn't sell because they never wore out and nobody needed a replacement. He found that the king pins were over engineered and rarely broke or wore out....... so he went back to his engineers and had them made thinner and smaller. If you think about it, this makes sense. It saves money on materials and in theory all the parts should wear out at the same time on a car. Well it should if you're in the business of making and selling new ones. Quote Link to comment
