Thomas Perkins Posted January 10, 2023 Report Share Posted January 10, 2023 (edited) On 12/28/2022 at 3:37 PM, Datsun pickup said: Does anyone know how to shut off the interior dome light on Nissan 720? It won’t shut off when the drivers door is open. Not suppose to shut off when the door is open.Unless you have it set on the off position.If you have it on the off position and light comes on.Then the switch in the light may be bad.Take it off and check out the connections and both door switches.The door switches may be stuck.Mine was.Shoot some wd-40 in there,worked for me.They have some for the 4x4 for sell on Ebay...Nissan still sells the bulbsI, bought 2,one for a spare.The one's at Auto part stores are not the right ones.Bulb 12V-10W Edited January 10, 2023 by Thomas Perkins Quote Link to comment
datzenmike Posted January 10, 2023 Report Share Posted January 10, 2023 If you have a king cab the interior light has a switch on it to select off. All others you have to have the door closed. Quote Link to comment
Datsun pickup Posted January 10, 2023 Report Share Posted January 10, 2023 I have to run the wires. Where is the tach resistor? Quote Link to comment
datzenmike Posted January 10, 2023 Report Share Posted January 10, 2023 The 720 already has the tachometer wires in the harness ready to use. Plug tach into the dash and good to go. On the '83 and up 7200 the tach resister ... ... is between the left headlights and the coils. It will present as a taped up lump on the harness. Quote Link to comment
Datsun pickup Posted January 15, 2023 Report Share Posted January 15, 2023 Is the clutch Slave cylinder (on the side of the transmission) supposed to spring back when the rod is pushed? Quote Link to comment
Datsun pickup Posted February 22, 2023 Report Share Posted February 22, 2023 How do you wire up the oil pressure and volts gauge in a 2wd. Quote Link to comment
datzenmike Posted February 22, 2023 Report Share Posted February 22, 2023 You mean the oil and volt gauges from a 4x4? You will need the gauges and the wire harness* on them. This 'mini' harness is a a foot long and connects into the dash harness on the right side of the heater. A dual oil pressure sender that both works the gauge and the red low oil pressure light in the dash. As I see it the early 2wd did not have the harness for the gauge cluster but '83 and up did, so you should have the dash connections that connects to the gauge harness*. The dash harness connectors that the gauge harness plugs into may be tapped up out of the way under the dash. If so this will make things much easier. You won't have the dual wire connection to the dual oil pressure sender on you 2wd engine harness. I just run an extra wire (for the gauge part of the sender) back to the gauge in the cab. Quote Link to comment
85 720 king cab 4x2 Posted August 10, 2023 Report Share Posted August 10, 2023 You don’t happen to have a picture of what it looks like for the mini harness to connect to buy the heater do you??? Quote Link to comment
Datsun pickup Posted September 30, 2023 Report Share Posted September 30, 2023 I am replacing the mirrors and I am not sure why, but my mirror screw holes are not even on both sides. the left side is good, but on the right side the holes are too far apart. Quote Link to comment
