SHORTDOG Posted June 26, 2012 Report Share Posted June 26, 2012 Does anybody know where i can find the factory paint codes for the Nissan 720's for 85-86.5? I know they didn't have that many factory colors during these two year models but any leads would help greatly! Thanks in advance guys! B) Quote Link to comment
datzenmike Posted June 26, 2012 Report Share Posted June 26, 2012 #002 #006 #015 #130 #505 #518 #663 #688 #804 #805 #806 #807 #809 #810 #924 I think these are right and they are not '85/86 specific ... most are from '82 none are newer than that. Quote Link to comment
SHORTDOG Posted June 26, 2012 Author Report Share Posted June 26, 2012 Thanks Mike, but i am not sure that will help me as i am trying to get the exact same color that is on my truck now. It is an 85 and it looks to be a root beer brown metallic paint color. Quote Link to comment
datzenmike Posted June 26, 2012 Report Share Posted June 26, 2012 #015, #810 was marked as 'Brown' ... Guess you need a color swatch to compare Quote Link to comment
ggzilla Posted June 26, 2012 Report Share Posted June 26, 2012 Does anybody know where i can find the factory paint codes for the Nissan 720's for 85-86.5?Yes, the codes are under the hood on the ID plate. Quote Link to comment
datzenmike Posted June 26, 2012 Report Share Posted June 26, 2012 Wa hahaha what he said. #505 Quote Link to comment
SHORTDOG Posted June 26, 2012 Author Report Share Posted June 26, 2012 What does the "G" stand for? Is that the interior color code? Quote Link to comment
ggzilla Posted June 26, 2012 Report Share Posted June 26, 2012 Yes, the second part is the interior color, G = charcoal gray. Quote Link to comment
SHORTDOG Posted June 27, 2012 Author Report Share Posted June 27, 2012 Yes, the second part is the interior color, G = charcoal gray. Mine says "C" , what color is this?......Camel? Quote Link to comment
ggzilla Posted June 28, 2012 Report Share Posted June 28, 2012 haha, i only know what G stands for, don't know what other interior codes there are Quote Link to comment
SHORTDOG Posted June 28, 2012 Author Report Share Posted June 28, 2012 Well i am no expert or anything but if i remember right, 720's only came in 3 different interior colors right? So i am thinking.... G = Grey ( Which is actually black with gray trim) B = Blue C = ?? has to be the tan color interior (so i am assuming "C" stands for Camel) what else could it stand for....right? Quote Link to comment
ggzilla Posted June 28, 2012 Report Share Posted June 28, 2012 You are so logical. Quote Link to comment
SHORTDOG Posted June 29, 2012 Author Report Share Posted June 29, 2012 Logically speaking! :w00t: lol! :rofl: Quote Link to comment
Datsun pickup Posted October 7, 2021 Report Share Posted October 7, 2021 Does anyone know what color code #106 is for the 1985 720 model year? Or what trim code b is? Quote Link to comment
Datsun pickup Posted October 7, 2021 Report Share Posted October 7, 2021 Does anyone know what Nissan model nl-stuf is? Quote Link to comment
datzenmike Posted October 7, 2021 Report Share Posted October 7, 2021 # 106 Blue Mist Metallic B, C and G are codes for upholstery trim. B=Blue, C=Brown and G= Black. Paint codes of... White #002 and Dark Blue #518 also use the same upholstery trim. If your color code is #355 that's a complementary two tone with #106 and #518 (Blue Mist Metallic and Dark Blue) Thanks, had to look this up so we both learned something. Quote Link to comment
Datsun pickup Posted October 9, 2021 Report Share Posted October 9, 2021 Does anyone know how to fix a leak underneath the cowl cover on the passenger side? It is leaking pretty bad onto the floor. Quote Link to comment
Datsun pickup Posted December 13, 2021 Report Share Posted December 13, 2021 Does anyone know how to tell what trim model (base, deluxe, or sport) a Nissan 720 pickup is? Quote Link to comment
datzenmike Posted December 13, 2021 Report Share Posted December 13, 2021 On 10/8/2021 at 5:58 PM, Datsun pickup said: Does anyone know how to fix a leak underneath the cowl cover on the passenger side? It is leaking pretty bad onto the floor. It could be several things including a bad windshield rubber seal or a rusted seam. But lets hope it's this as it's easy to fix... Remove the wiper arms from the pivots, unscrew the louvered plenum cover and remove. Use a flashlight and look in that right side corner and you'll see the opening for the air inlet to the heater fan. It has a small raised lip to keep water out but over past it to the outside is a drain hole for trapped water. This is easily blocked by debris that falls through the louvers, such as pine needles and maple keys. Clear that drain and the water won't collect and spill down the inlet. This drain empties behind the right fender in front of the top door hings Quote Link to comment
Datsun pickup Posted January 23, 2022 Report Share Posted January 23, 2022 I fixed the leak by caulking the raised lip, because water was dripping down into the heater fan through the base of the raised lip. Quote Link to comment
Datsun pickup Posted December 28, 2022 Report Share Posted December 28, 2022 Does anyone know how to shut off the interior dome light on Nissan 720? It won’t shut off when the drivers door is open. Quote Link to comment
datzenmike Posted December 28, 2022 Report Share Posted December 28, 2022 On 1/22/2022 at 5:23 PM, Datsun pickup said: I fixed the leak by caulking the raised lip, because water was dripping down into the heater fan through the base of the raised lip. Check that the cowl drains are not obstructed by pine needles and maple keys. Quote Link to comment
datzenmike Posted December 28, 2022 Report Share Posted December 28, 2022 5 minutes ago, Datsun pickup said: Does anyone know how to shut off the interior dome light on Nissan 720? It won’t shut off when the drivers door is open. The King Cab interior lamp has a three position switch that can be turned on with the door shut, turned on when the door is open or you can select OFF. I would guess that if you get one from a King Cab you may be able to fit it to your truck. Quote Link to comment
Datsun pickup Posted January 9, 2023 Report Share Posted January 9, 2023 I have a 1985 Nissan 720. Where do the tachometer wires go? I am trying to install a tachometer. Quote Link to comment
datzenmike Posted January 9, 2023 Report Share Posted January 9, 2023 Factory tach? Just plug it into the dash. Quote Link to comment
