rad510 Posted June 9, 2012 Report Share Posted June 9, 2012 Need help .. get me some information Quote Link to comment
DAT510 Posted June 9, 2012 Report Share Posted June 9, 2012 Yes Sir! Sir, Check fuses, Sir! Then proceed to give us some details,Sir!! Quote Link to comment
ggzilla Posted June 9, 2012 Report Share Posted June 9, 2012 When all the turn signals don't work, check first: * Fuse, pull it out even if it looks good then put it back When the turn signal is stuck on, replace the flasher unit When the signal doesn't work on one side, look for a burnt-out bulb (front, rear and dash) Quote Link to comment
Laecaon Posted June 9, 2012 Report Share Posted June 9, 2012 Also If the front turn signals are not wired correctly, it will mess up the signals. I have experienced this. 1 Quote Link to comment
banzai510(hainz) Posted June 9, 2012 Report Share Posted June 9, 2012 Also If the front turn signals are not wired correctly, it will mess up the signals. I have experienced this. well we would hope it was working before this. Most times its a bad bulb. swap the flasher cans or ck the alternator for low out put Quote Link to comment
