SD_GOON Posted June 5, 2012 Report Share Posted June 5, 2012 Hey guys, after a long battle with my ignition system I finally got my wagon running but its not charging. I bought a new alternator and voltage regulator because they were both bad. I have also checked to see if my dash bulbs were good because I saw on another post that could also cause charging issues. I replaced two but it still no charge. I have no idea what the problem could so so I would really appreciate some help here. Thanks Quote Link to comment
banzai510(hainz) Posted June 5, 2012 Report Share Posted June 5, 2012 ck your fuses in the fuse box make sure they good. soemtimes they can look good but are broke at the ends. what was this battle with the ignition system. IM sure the ignition routes 12volts to energise the field in the alternator. Quote Link to comment
ggzilla Posted June 5, 2012 Report Share Posted June 5, 2012 That's true. The IGN circuit energizes both the coil and the alternator. Time to start measuring voltage. * With key ON engine OFF is there 12V at the back of the alternator at the F connection? * With key OFF, is there 12V at the alternator A/BAT terminal? * Is there 12V between alternator E terminal and battery POS terminal? Quote Link to comment
datzenmike Posted June 5, 2012 Report Share Posted June 5, 2012 Only the CHG bulb needs to be working for it to charge. I bought a new alternator and voltage regulator because they were both bad. How do you know they were bad if you replaced them and it still doesn't charge? Quote Link to comment
SD_GOON Posted June 5, 2012 Author Report Share Posted June 5, 2012 ck your fuses in the fuse box make sure they good. soemtimes they can look good but are broke at the ends. what was this battle with the ignition system. IM sure the ignition routes 12volts to energise the field in the alternator. It looks like all the fuses are good. The ignition battle was that I pretty much had to replace everything. New coil, new distributor and all the wiring was a mess. I followed the diagrams I found here on ratsun to hook everything up. That's true. The IGN circuit energizes both the coil and the alternator. Time to start measuring voltage. * With key ON engine OFF is there 12V at the back of the alternator at the F connection? * With key OFF, is there 12V at the alternator A/BAT terminal? * Is there 12V between alternator E terminal and battery POS terminal? There is 8V to the F connector with the key on 12V to the A terminal with key off. 12V between POS terminal and E Only the CHG bulb needs to be working for it to charge. How do you know they were bad if you replaced them and it still doesn't charge? I got the alternator checked at the auto part store and it was bad. The voltage regulator I bought because I assumed it was bad. I can always return it. Checking the fuses with a circuit tester lead I think I discovered a short. When I touched the flasher fuse terminal with horn terminal I heard a crack on the starter I believe. :hmm: Quote Link to comment
ggzilla Posted June 5, 2012 Report Share Posted June 5, 2012 Good so you tested the fuses instead of relying on looks. I heard a crack on the starterThat could be a bad connection at the starter battery cable. Loose or dirty connection. Clean both ends of the battery cable and re-tighten. Quote Link to comment
banzai510(hainz) Posted June 6, 2012 Report Share Posted June 6, 2012 I think you cant return electrical parts once YOU say its used. Quote Link to comment
SD_GOON Posted June 8, 2012 Author Report Share Posted June 8, 2012 Hey guys, just wanted to let you know that after giving my fuse box a thorough cleaning the goon is charging now. :thumbup: I appreciate all the help from everyone. Quote Link to comment
banzai510(hainz) Posted June 8, 2012 Report Share Posted June 8, 2012 thats great,I was close with the fuse box. Quote Link to comment
