sjeff64 Posted May 9, 2008 Report Share Posted May 9, 2008 I just bought a set of E3 spark plugs, they are expensive about $6 each but they have a 5yr/100,000 mile warranty(yes I mean 100 thousand mile)my truck has never ran this smoooth!! I was seeing how slow I can idle and still be smooth with the throttle response, when I got to 500rpm I thoght ih crap this is rediculious! I think it is worth the $6 a plug Quote Link to comment
Llittle_Llama Posted May 9, 2008 Report Share Posted May 9, 2008 so what if you foul them out? covered? Quote Link to comment
hang_510 Posted May 9, 2008 Report Share Posted May 9, 2008 snake oil? to clean expensive fouled plugs? :fu: Quote Link to comment
Guest DatsuNoob Posted May 9, 2008 Report Share Posted May 9, 2008 Eeeetheeerrrrrrrr!!! Quote Link to comment
fiveNdime Posted May 9, 2008 Report Share Posted May 9, 2008 Fire, Fire, Fire!! Quote Link to comment
ggzilla Posted May 10, 2008 Report Share Posted May 10, 2008 I remember way back when Car Craft tested the then-new Accel SplitFire plugs. YES. they did increase power. But then so did new regular plugs at 1/5 the cost. Quote Link to comment
datzenmike Posted May 10, 2008 Report Share Posted May 10, 2008 Yup! A spark plug is a spark plug is a spark plug. Quote Link to comment
ggzilla Posted May 10, 2008 Report Share Posted May 10, 2008 A spark plug is a spark plug is a spark plug.I'm sure that platinum plugs are slightly better: Last longer, etc. Am I mistaken? Quote Link to comment
datzenmike Posted May 10, 2008 Report Share Posted May 10, 2008 Actually I run platinum in my L20B about 5-6 years ago. You know I haven't thought about them once in all that time... never checked them once and they are still in there. Guess they work ok.:D Been across Canada at least three times on 'em. Quote Link to comment
sjeff64 Posted May 12, 2008 Author Report Share Posted May 12, 2008 yes it was more because they are new and once I put them in I can just forget them. but you know what with these I turnd the idle dowwn to 350 rpm and still had good throtle response Quote Link to comment
