brodster Posted May 19, 2012 Report Share Posted May 19, 2012 So I am in the process of replacing the control arm bushings. I bought a set of Prothane bushings about a year ago in anticipation of the overhaul. The only problem is that the bushings don't bit in the LCAs. It appears that if I remove the inner metal sleeve in the photos that the bushing will go in. I did some searching and I found one thread on the realm showing someone hacking out that inner sleeve: http://www.the510realm.com/viewtopic.php?f=1&t=9365. They had the same question. Two questions: Is this normal with bushings from prothane or energy suspension? Is the method on the realm the best way to get this done? I just don't want to screw up my control arms, and I want some advice from people who have done this. Thanks Quote Link to comment
john510 Posted May 19, 2012 Report Share Posted May 19, 2012 I had to remove the metal sleeve to get new bushings in.I cut a groove in the steel sleeve(carefully)so i didnt screw up the control arm.Then peeled it out with screwdriver.I tried heat,wd-40,a press,and more heat.Those sleeves would not budge. Quote Link to comment
q-tip Posted May 20, 2012 Report Share Posted May 20, 2012 The metal sleeve is the outer part of the origional rubber bushings, at least the ones i took out of my car. If you are puting adjuatable tc rods you need use rubber bushings or get adjustble lcas, the poly bushings will bind and fail eventually. Quote Link to comment
Logical1 Posted May 20, 2012 Report Share Posted May 20, 2012 I have cut several (ruined) LCA's apart to examine the design and look for the 'sleeve' All the LCA's I inspected did not have them... However they were most likely from 70-73' 510's so I can't vouch for all years. So when I replaced my bushings, I decided to reduce the bushing size. I chucked them up in a drill press and sanded them down. You can see the technique near the bottom on my build thread: http://community.rat...ss/page__st__40 I used the poly bushings for several years now and they are still in great shape with no problems, I'm hard as shit on my car too! Quote Link to comment
brodster Posted May 21, 2012 Author Report Share Posted May 21, 2012 Thanks for the help. I ended up using a drift, hammer, hacksaw and dremel tool to get the job done. It took forever and only gouged the inner surface once. Not too bad. Quote Link to comment
