FiveSeventyZee Posted May 23, 2012 Author Report Share Posted May 23, 2012 got the firing order fixed and it started right up. still rough though. the valves make a little noise I think there's too much valve lash. also the spark timing seems a lot late with not enough adjustment in the distributor so I'll have to move it a tooth to get the right range of adjustment on the distributor and I should be back on the road. thanks guys. I knew it would be some stupid user error Quote Link to comment
banzai510(hainz) Posted May 23, 2012 Report Share Posted May 23, 2012 This would be EZ to spot with the timming light!!!!!!!!if off a tooth and your out of adjustment on the timming plate(no more slot left to adjust) this is why I said pull the 10 mm bolt and adjust it then lock it down with a C clamp and run it and if fine then you know its the proplem. You can do this in the parking lot at work Quote Link to comment
FiveSeventyZee Posted May 28, 2012 Author Report Share Posted May 28, 2012 so I've got it running now but it runs awful...there seems to be huge amounts of vibrations from the engine and it is nowhere near as smooth as it was before. it hesitates on start up and when I raise the revs. improvements from before is really that it can now idle without my help. a good amount of oil smoke is coming from the fitting on the valve cover and the crank case recirculation pipe. neither of which have anything on them currently but never did before. I tried running it at 2k rpms for a while. did about 10 min before it started acting weird. revs seemed to be raising and lowering without me moving my foot (maybe it was just getting smoother and rougher my tach wiring needs to be cleaned up because te needles jumping all over the place) so I let off the gas to let it idle and there was almost a squeaking sound from the engine. I can take a video of it I just wanted to check to see If it sounded like anything horrible that I need to fix before I start the engine again Quote Link to comment
d510addict Posted May 28, 2012 Report Share Posted May 28, 2012 If you went from a regrind to a stock cam you may have the wrong lash pads in, I went through something similar to what you are going through now. Check list: Wipe pattern on your rockers should be centered Lash should be set .008" intake .010" exhaust (cold) Mechanical timing should be set so your v notch lines up (looks like yours is correct) Ignition timing should be set correctly tuned carb having your firing order correct 1342 as they said above, just make sure where your #1 position is new plugs if yours are fowling With a a diff grind cam your carb settings may be off. do you have oil? Should take a few hours to do all that (unless you check every rocker wipe {1 exh and 1 int should be all you need to check to know if there is something wrong though}). Quote Link to comment
FiveSeventyZee Posted May 28, 2012 Author Report Share Posted May 28, 2012 everything on that list other than the carb and the wipe pattern have been done. I'll check the wipe pattern probly tomorrow and go from there. at this time I'm thinking about having a new peg pressed into the reground cam so I can throw it back in rather than getting new lash pads (if the wipe pattern is off centered that is) Quote Link to comment
FiveSeventyZee Posted June 4, 2012 Author Report Share Posted June 4, 2012 wipe pattern came up off centered. I got the pin reset in the reground cam and put it back in but there's still a really bad sound coming from the engine. hard to describe so here http://i1015.photobucket.com/albums/af278/jgong9609/5c1163df.mp4 anybody know what could possibly make that sound? Quote Link to comment
banzai510(hainz) Posted June 4, 2012 Report Share Posted June 4, 2012 sounded like it was running on 2 cylinders if that. lash pads fall out? I always have a spare L16 210 head(worth about 25-50$ nodays) for trouble shooting. Best to use or find one for trouble shooting. Quote Link to comment
ggzilla Posted June 5, 2012 Report Share Posted June 5, 2012 timing seems a lot late with not enough adjustment in the distributor Did you get that fixed? Is the timing correct now? Quote Link to comment
