Oregon_PLG222 Posted May 15, 2012 Report Share Posted May 15, 2012 Does anyone have a picture of what the 521 front drum brakes should look like? When I bought this one they told me they had put new pad on it. The brakes were real soft and I had to pump them. They also pulled to the right. So, after I got it running decent re-did the wheels and put new tires on it, I took it to Les Schwab to look the brakes over. They said the pads were put on backward on on side on the front. I thought they said the passenger side. So, when I got it home I pulled the drum off and compared it with the repair manual which doesn't show a lot of detail. It looked O.K. So, I pulled the driver side off and it matched the passenger side. I'm pretty sure I need to replace the master cylinder and re-do the wheel cylinders. But, I don't know if the pads are on wrong. I should have taken a pic while I had the drums off. Also, any suggestions regarding the purchase of a master cylinder and the wheel cylinder kits? I got some info in a response from the 521 page. I thought I'd put it here on the brakes section. I'd still like to get a picture of what they should look like. Quote Link to comment
mklotz70 Posted May 15, 2012 Report Share Posted May 15, 2012 couple here that might help....maybe. They're 320, but should be pretty dang close to 521. http://www.bluehandsinc.com/truck-kit-install.html Quote Link to comment
Oregon_PLG222 Posted July 7, 2012 Author Report Share Posted July 7, 2012 What's a good vs. bad master cylinder to purchase an where can I get one? Quote Link to comment
banzai510(hainz) Posted July 7, 2012 Report Share Posted July 7, 2012 anything Made in Japan is best. nabco/tokico most I have seenit taiwan/Italy made stuff. wheel cylinders dont come with the Y pipe/bleed/hook up. 3/4 or 13/16 dont matter to me. they close enough in my opinion Master cylinders one has to adjust the threaded rod that goes to the pedal. I notce mine were all to long and hadto hackway about 1/2 off. Otherweise the pedal pushed the rod into the master thus putting pressure. Im running a cast iron Doorman brand(Taiwan) 1 Quote Link to comment
