Rambler73 Posted May 9, 2012 Report Share Posted May 9, 2012 I have a 73 620 with a L18 4speed. I'd like to put a 5speed in . But dnt want to have to mess with changing anything else. Wat cars or trucks work? I know there's. Part numbers on trans that tell u what they r right?? Where is it located and how do I know what the numbers mean. Help me :) Quote Link to comment
Eagle_Adam Posted May 9, 2012 Report Share Posted May 9, 2012 use the search button - or google http://www.google.com/search?q=5+speed+swap+-+ratsun+&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a Quote Link to comment
datsunaholic Posted May 9, 2012 Report Share Posted May 9, 2012 "Without changing anything else". Then you're stuck. Any 5-speed will require changing at least one other thing. The transmission crossmember has to have some changes/mods no matter what you do, though it's not as extensive as what it takes to do the swap in a 510. Most transmissions don't have part numbers on them. They have partial IDs that may or may not be unique. Quote Link to comment
datzenmike Posted May 9, 2012 Report Share Posted May 9, 2012 Check the build date on the drivers door jam. If built from October '73 it should have the F4W71B 4 speed in it along with the L18. Another check is to measure the length of the tranny. If it's close to 31.5" then you should be able to fit a later optional 620 FS5W71B5 speed in. The 620 cross member and rear mounts are the same for all automatic, 4 and 5 speeds after Oct '73. Use your release bearing carrier or sleeve you have now. You can also swap your 4 speed speedometer drive pinion into the new 5 speed if you don't know what it came out of, to keep your speedo accurate. You can use either 4 or 5 speed shifter. L series FS5W71B (5 spds.) that will (drop in) fit. '77-'79 620 truck '77-'78 280z '79-'83 non turbo 280zx '79-'84 810/Maxima '80 720 (2wd) truck If built before Oct '73 it should have an L16 (yours could have been swapped to L18 I guess) and a much shorter F4W63L 4 spd. If it measures about 26" then this is the case and there is no 'drop in' 5 speed although the '77-'79 200sx FS5W63A dogleg 5 speed is the easiest. It's the same length as the 4 speed but the rear transmission mount will need to be modified. Your speedo pinion from the F4W63L can be swapped into the dogleg to keep your truck speedometer accurate. Quote Link to comment
ggzilla Posted May 9, 2012 Report Share Posted May 9, 2012 If built from Oct 1973, then it is a 1974 model. Sometimes the Title has the wrong year. Quote Link to comment
datzenmike Posted May 9, 2012 Report Share Posted May 9, 2012 Yup, always refer to the door tag. Quote Link to comment
Rambler73 Posted May 10, 2012 Author Report Share Posted May 10, 2012 Next time I'll hit the search bottom. Thx fOr The help. Ill take a look at the truck this weekend and see wat I got. I was more worried on drive shaft not fitting. Changing the rear mount dnt seem to hard. Quote Link to comment
Rambler73 Posted May 11, 2012 Author Report Share Posted May 11, 2012 Well it's about 26" and I dnt have a door sticker. I'll b looking for a dogleg 5sp, hopefully local or a good deal with shipping. Quote Link to comment
