Sign in to follow this
Z chopper
wtb: '72 510 stuff.
here is a short list of things I need, I am sure it wil grow
rear bumper w/ Brackets and front bumper (need by end of may)
Interior Rear Pillar vents
drivers side lower rear quarter or whole quarter panel
620 centre console (i already have the jockey box)
2x 521 speaker boxes
green lighter (280z/zx?)
Cam Oil Spray Bar (z/zx spray bar shortened or L16 nismo)
240z Flat top pistons
'70-'73 510 Tail lights w/harnesses (need by end of may)
green headlight and washer switches from 620
70-72 tail light panel rear lower valance (I think that is what it is called)
front drivers side floor tnx datwifey and brodster
I am in Canada so shipping is required.
shipping will be to
Nanaimo, BC
Canada
V9S 4R5
Share this post
Link to post
I think I have an extra set of buckets... Since I switched to GL tails, normal buckets no longer fit.
Share this post
Link to post
kool a couple people are checking thier stashes, right where the back up bulbs goes is a little broken and won't hold the bulb in
Share this post
Link to post
I just looked (my stash is mostly in my living room) and it looks like the twist connections are good. They are pretty dirty though...
Share this post
Link to post
One connection looks a little off, so let me take it to my car and check condition tomorrow. Ill screw the lights in and out to check condition.
Share this post
Link to post
i have a tail light panel in very workable condition, lower valance is shot though. i also have lower quarters that are in fair condition too.
Share this post
Link to post
sending you a pm
Share this post
Link to post
I have a complete rear clip in excellent condition. Not sure how to go about shipping the panels though.
Share this post
Link to post
maybe the lower rear valance?
Share this post
Link to post
I'm very busy with exams at school and am not home often, give me some time to get the pictures up
Share this post
Link to post
510freak was over dropping some stuff off the other day and checked out my 510 he pointed out that there is supposed to be somesort of white box for the choke system here.
so that white box is on my want list now.
edit: noted that the white box is not needed
Share this post
Link to post
tail light harnesses ae also on my list as you can see the sun rot mess up the bulb sockets.
Share this post
Link to post
quite possible, do you mean the one that goes between the body and the taillights?
Share this post
Link to post
The white box is stuff to deal with a dual points distributor. Most 510's don't have them because they rip all that crapola out of their dime. It's not needed unless you want it to be bone stock. Personally I can't think of a reason why somebody would to find one of those unless they absolutely needed it. Same goes for the relay mounted on the radiator. I ripped all that crap out and removed it entirely from the harness many years ago.
Plus, most of those parts are old worn out and don't even function any more. I wouldn't focus money on something like that until you know for sure if you want to even have it. IMHO it's just another thing to go bad in an engine bay and as most of you know, I'm not exactly a fan of dual point distributors, so maybe I'm biased?
Share this post
Link to post
great info boaty. I am not a fan of points distributors/ignition in any vehicle give me ei dizzy in my datsun and cdi in my minibikes
Share this post
Link to post
Well if you're going to be running an electronic ignition, you don't need the white box/throttle switch. You can ignore that. You can also remove the relay off the radiator as well. Not sure on what year this was, but I'm pretty confident it's all third gear/throttle positiion stuff on the later 510's for smog. I can't imagine any of it being of benefit... Hell it could be used on automatic stuff as well. No clue. :/
But I'm confident you can remove that from your list, unless you're wanting it for... aesthetics.. or something. Lol.
Share this post
Link to post
