510 Crossmember LCA Pivots. Is this normal?
brodster
Pulling my 510 apart in the front to overhaul suspension, brakes, etc. I am no suspension expert, but it seemed unusual that the LCA pivots were at such different angles. Is this normal? Perhaps this is the way they set it from factory?
I don't remember any abnormal camber or tire wear, but that was over three years ago.
Thanks
  • Replies 8
those are after market they use to use those to adjust camber
And that explains why none of the drawings show those pieces.
Currently I am rebuilding everything. I am putting in camber caster plates and coilovers. Should I just pull those things off then?
Thirded'.
Remove those.
Akward way to adjust camber. This is 2012, and we all have camber plates, coilovers, adjustable control arms, adjustable T/C rods, and bumpsteer spacers galore.
It kind of reminds me of the offset control arm bushings... I would never run those on my dime, I would never trust them.
haha that is what Mikey just pulled out of his car when I sold him a set of my LCA's
yeah you need new pins. i have a spare set that I could probably part with since you need them on crunch time.
if you are interested PM me, Im south of you just outside of vancouver
