betojr82 Posted April 19, 2012 Report Share Posted April 19, 2012 pardon my ignorance on the subject :sleep: i have a 77 b210. . are there any other rear ends that fit my car? that would be like a upgrade to my car. i know there is, the real question i wanna ask is that if they are a direct bolt on or is there some welding and shortening required. i wanna upgrade the rear end but dont know where to start Quote Link to comment
DRIVEN Posted April 19, 2012 Report Share Posted April 19, 2012 No bolt in that I'm aware of. What do you need to "upgrade" it for. Better gearing? Too much engine? The H150 you have is pretty sturdy behind most mild A-motors. Quote Link to comment
betojr82 Posted April 19, 2012 Author Report Share Posted April 19, 2012 No bolt in that I'm aware of. What do you need to "upgrade" it for. Better gearing? Too much engine? The H150 you have is pretty sturdy behind most mild A-motors. i want better gearing and it to be able to handle the massive power of a stock 13b :rofl: . . some people tell me to use a ford rear end others to use one off of a pathfinder. Quote Link to comment
datzenmike Posted April 19, 2012 Report Share Posted April 19, 2012 '82-'83 S110 (200sx) has an H-190 with rear disc brakes. It is set for coil springs but anyone with a grinder and welder could add spring perches for the B-210 leaf springs. Quote Link to comment
betojr82 Posted April 19, 2012 Author Report Share Posted April 19, 2012 '82-'83 S110 (200sx) has an H-190 with rear disc brakes. It is set for coil springs but anyone with a grinder and welder could add spring perches for the B-210 leaf springs. thanks for your help. . . Quote Link to comment
jaime.g Posted May 8, 2012 Report Share Posted May 8, 2012 '82-'83 S110 (200sx) has an H-190 with rear disc brakes. It is set for coil springs but anyone with a grinder and welder could add spring perches for the B-210 leaf springs. this is what i'll be doing with my 76 b210. I've purchased the rear end already but it's been sitting for a while as the project is on hold. The one I picked ended up coming with a 3.5 ring gear. You can find out what gear it has on the plate that is usually located in the engine bay on the firewall. Quote Link to comment
ggzilla Posted May 8, 2012 Report Share Posted May 8, 2012 You can get a 4.625 ring gear for it for drag racing. Quote Link to comment
Dime Dave Posted May 8, 2012 Report Share Posted May 8, 2012 The good thing about the 200SX H190 is the 620 truck centers are a direct swap. The 200SX used the bigger "truck" axle splines. 4.375:1 ratios are readily available and with a rotary you'll want something lower than a 3.54. The stock ratio in a rotary pick-up was 4.87. Spun the bearings right out of that poor 289 V8 I stuff into one years ago. Quote Link to comment
drowning in broken cars Posted June 29, 2012 Report Share Posted June 29, 2012 Im also hunting for a rear end thatll handle a ka swap, Searched all around and havent been able to find any 200sx rear local to me. was gonna try and just fab up something but was thinking of the pathfinder rear as it coilspring, right? only thing I was wondering is what have people done to convert it back to 4 lug? is there a known easy way to do this? thanks Quote Link to comment
datzenmike Posted June 29, 2012 Report Share Posted June 29, 2012 The H233 is MASSIVELY heavy and larger than a Ford 9". Overkill and a lot of work. Quote Link to comment
drowning in broken cars Posted June 29, 2012 Report Share Posted June 29, 2012 noted. back to the drawing board. looks like no matter what I do il have to fab something up. what are people doing to go back to 4 lug or are they? with ford 9s and such Quote Link to comment
datzenmike Posted June 29, 2012 Report Share Posted June 29, 2012 I guess re-drill the drum and axle and press in studs. The stock rims ma ot fit over the Pathfinder or D21 drums. Quote Link to comment
