bagged320 Posted April 30, 2008 Report Share Posted April 30, 2008 How do I take my steering column off my 320 and can it be lowered, im planning on body dropping my truck, maybe, and just wondering if there was another way to go with steering columns or before I start tearing into the column if there is a easy way to get it off, i need to take the body off to clean and paint the frame, I just remember taking the one off on my 521 a few years back was a pain Quote Link to comment
Rusty Posted April 30, 2008 Report Share Posted April 30, 2008 :lol::lol::lol::lol::lol::lol::lol::lol::lol::lol: cut that death trap out and put rack and pinion and ah tilt column in it...:cool: butit comes out? somehow? my frustration led me to the above idea... Quote Link to comment
Llittle_Llama Posted May 1, 2008 Report Share Posted May 1, 2008 damn, thats strong like bull, lol :lol::lol::lol::lol::lol::lol::lol::lol: Quote Link to comment
bagged320 Posted May 1, 2008 Author Report Share Posted May 1, 2008 Ya im trying not to cut it, I remember taking it apart somehow on my 521 but dont remeber how and if it worked after that, but I might just get so frustrated that I might just hack it off Quote Link to comment
]2eDeYe Posted May 1, 2008 Report Share Posted May 1, 2008 Remove the steering wheel and the blinker switch cover and assembly. Disconnect the drag link. Unbolt it from the frame, the firewall and the dash. Then you have to finaggle (technical term) it out from the engine bay. Quote Link to comment
datsunaholic Posted May 1, 2008 Report Share Posted May 1, 2008 "Unbolt the drag link". Redeye, you've been working on your jeep too much. Well, on a 320 that's be "unbolt the pitman arm" since it attaches directly to the tie rod. If you're going to take the cab off, you can just unbolt the pitman and the steering box from the frame, wire it to the cab and lift it off when removing the cab. I'm not sure you can remove it from a 320 with the engine in place, at least not intact. But in reality if you are body dropping you'll have to replace the steering anyway since the column is solid and would end up going through the speedometer. Best bet is to get a 720 steering setup since it has "tilt" and the ability to change the angle. Fabrication will be reqired no matter what you do. Quote Link to comment
bagged320 Posted May 2, 2008 Author Report Share Posted May 2, 2008 ended up getting mad and frustrated so I just cut it, and decided to put in a tilt Quote Link to comment
Llittle_Llama Posted May 2, 2008 Report Share Posted May 2, 2008 lol, i think we all assumed that would happed :D Quote Link to comment
