VintageRice Posted April 4, 2012 Report Share Posted April 4, 2012 Ok, When I bolted my Ka trans to my motor(sohc) i thought that the bottom of the flywheel/clutch area that was open just had a blockoff plate there that I was missing and could put it on later.. Now, after looking at some pictures, I see that maybe it was supposed to go BETWEEN the motor and trans. Am I screwed not having it there?? I do I need to get one and pull the tans out and bolt it in. This REALLY sucks if so cause the motor and trans are already in without this mysterious plate. Anyone have a pic of one? Datzenmike ? ? ?? Heres all I could find but its for a automatic ka24de. I have a Manual Ka24e. Quote Link to comment
datzenmike Posted April 4, 2012 Report Share Posted April 4, 2012 Yup needs to be there. It actually is mounted behind the flywheel, goes on first. The transmission is going to be that spacer thickness closer to the engine and may affect the clutch action. Starter to starter ring should be unaffected. It will likely run and work but you don't want water and mud splashed in there anyway. What about a stone thrown up by a wheel getting in there? Better get it right. Quote Link to comment
VintageRice Posted April 4, 2012 Author Report Share Posted April 4, 2012 SONOFA!! Arggggg........ Ok, where can I get one.......Another part I need to track down used?? U know the hardest parts I've had to find is the little stuff no one ever cares about. Thanks Mike. Thats what I was afraid of. Quote Link to comment
datzenmike Posted April 4, 2012 Report Share Posted April 4, 2012 It's for the best I think. Is yours a 240sx or D21 KA as they will have different spacer plates. Your picture is of a 240sx KA. Quote Link to comment
VintageRice Posted April 4, 2012 Author Report Share Posted April 4, 2012 its a 240sx ka24e Quote Link to comment
Draker Posted April 4, 2012 Report Share Posted April 4, 2012 Try Nicoclub or some other 240 forum Quote Link to comment
