Rynoise Posted April 4, 2012 Report Share Posted April 4, 2012 Just got this car back in November, and I love it! No major issues at all, until the other day it got stuck in 3rd gear. I pulled over in a parking lot and tried with all my might to get it out, and it wouldn't budge. Mine's a '79 with a 5-speed conversion. I'm guessing I need a new tranny, but where to look? I've been checking ebay and the local craigslist with no real luck. Any help would be appreciated, thanks! Quote Link to comment
I'm BLUE Posted April 4, 2012 Report Share Posted April 4, 2012 Check the gear fluid level lately? Any noise? No fast n flurious 3th gear drifting attempts right? Haha Quote Link to comment
datzenmike Posted April 4, 2012 Report Share Posted April 4, 2012 Yeah that's to be expected with a 34 year old transmission. It's likely a shift dog has come out of position and it's is truly jammed. Normal wear can do this. Forcing it could bend the shift fork. Try to locate a four speed so you can at least be on the road while looking for a five. Quote Link to comment
datzenmike Posted April 4, 2012 Report Share Posted April 4, 2012 http://community.ratsun.net/topic/41771-4-b210-5-speed-transmissions/page__fromsearch__1 Quote Link to comment
Rynoise Posted April 4, 2012 Author Report Share Posted April 4, 2012 There had been an occasional dull metal clang when I'd shift. But the issue showed up the day after I took it to jiffy lube, and the changed the fluid. From what I've heard, sometimes all the old gunk and whatnot in there's all that's allowing it to still work. I did see that a guy had a 4-speed up in Vancouver, I could just do that. Thanks! Quote Link to comment
Rynoise Posted April 7, 2012 Author Report Share Posted April 7, 2012 Does anyone know if a 1980 transmission will work? There's an '80 210 at the Pick and pull close by... Quote Link to comment
datzenmike Posted April 8, 2012 Report Share Posted April 8, 2012 If you have a '79 then you have a 210 not a B-210 so very likely the '80 will fit. What shift pattern is your old 5 speed? This.... 1..3..5 2..4..rev If so the 80 should be a perfect match. Quote Link to comment
Rynoise Posted April 8, 2012 Author Report Share Posted April 8, 2012 No, mine's a dogleg: r 2 4 1 3 5 Quote Link to comment
datzenmike Posted April 8, 2012 Report Share Posted April 8, 2012 OK there were two similar transmissions used in the 210 that were 5 speeds. One is a dogleg and the other a regular pattern. An earlier '76-'78 B-210 5 speed will also fit so it might be one of those. The first two 210 five speeds are very likely to swap will little problems. The B210 dogleg may have a different mount. Maybe ggzilla will comment on this if he's around. Can you provide a picture of the old transmission that is broken.?? Quote Link to comment
BillM Posted April 15, 2012 Report Share Posted April 15, 2012 The only difference between the two transmissions (5-speed ones) is the dogleg sits about 1/2" lower on the trans mount than the regular one- a difference that should be of NO consequence for a swap. The trans mount for the dog-leg is identical to the 4-speed one, the regular 5-speedis 1/2" taller. This is all for -60 transmissions only, not for -63 ones! BillM Quote Link to comment
