The datsun kid Posted March 12, 2012 Report Share Posted March 12, 2012 So I have a 71 521 and I took the tired l16 out and put a supposedly rebuilt l20b with 4speed out of a 77 710 in it so got it all put in and it didn't wanna start then we switched my l16 electronic dizzy with the points dizzy that was off the l20b and we advanced it alot it seemed like it anyhow and so it started and we got it running pretty good but the header studs are jacked so the header doesn't bolt up all the way so fat exhaust leak and it smokes pretty bad it's black smoke but it seems like it runs fine so how could it be that rich? So what did I do wrong? Oh and my cousin put 5qts in it I said it might be too much but he said that he put that in his Datsun with l20b any help would be awesome guys thanks Quote Link to comment
Guest 510kamikazifreak Posted March 12, 2012 Report Share Posted March 12, 2012 So I have a 71 521, I took the tired l16 out, put in a supposedly rebuilt l20b with 4speed,that came out of a 77 710. The dizzy that was in it,isnt so good so we put in and it didn't want start, we then switched my l16 electronic dizzy with the points dizzy that came off the l20b and we advanced it alot, it seemed like we did, anyhow,it started, we got it running pretty good but the header studs are broken, so the header doesn't bolt up correctly,the exhaust leak is loud and it smokes pretty bad. It's black smoke but it seems like it runs fine so how could it be that rich? So what did I do wrong? Oh yeh, and my cousin put 5qts of oil in it, I told him it might be too much, but he said that he put that in his Datsun with l20b . any help would be awesome guys thanks first thing proofread. that was one of the hardest things to try and decifer Quote Link to comment
datzenmike Posted March 12, 2012 Report Share Posted March 12, 2012 5 US qts with a new filter is fine. Can't run a header on a stock '77 motor without changing the intake. So what's the intake and carb from? Is the gas level with the dot on the glass bull's eye on the front of the carb? The choke will be on with a cold motor. Did you get it warmed up? The choke should turn off when warm. Quote Link to comment
The datsun kid Posted March 12, 2012 Author Report Share Posted March 12, 2012 Sorry my bad Im a little flustered persae lol I forgot to add i put the l16 oil pan and pickup also I have a 32/36 weber and the intake and Manifold is from my l16 non smog sorry Quote Link to comment
EricJB Posted March 12, 2012 Report Share Posted March 12, 2012 What is the level on the dipstick? With an oil pan from the L16, (521 only) that will clear the Tie rod and crossmember, it might not need 5 quarts. I only run 4 quarts in my L23/ 521. The 521 oil pan is pretty small. Quote Link to comment
The datsun kid Posted March 12, 2012 Author Report Share Posted March 12, 2012 The truck is at my uncles so I'll check it tomorrow but I'm pretty dam sure we overfilled it like dumbass's so I'll see what's up with it any reason why it needs to be advanced so far? Quote Link to comment
datzenmike Posted March 12, 2012 Report Share Posted March 12, 2012 You can always dump some out until the dipstick reads right. So a 32/36 that was jetted for an L16 is now on an L20B that it 25% larger. May need different jets. Quote Link to comment
The datsun kid Posted March 12, 2012 Author Report Share Posted March 12, 2012 No I have the weber that came with the l20b on it now it's the same 32/36 but like I said it runs good just smokes I'll post up tomorrow if it was the oil or not thanks guys Quote Link to comment
Jester Posted March 12, 2012 Report Share Posted March 12, 2012 ifyoudotryandproofreadyourshititreallysuckstotrytoreadsomethingthatsoundslikesomeonejustgotdonerunningamarithonandistryingtotellthestoryofhowtheholerunwentinonebreath. PUNCTUATION. Get it!!!! If you have to have the timing advance, you probably didn't get the distributor in on the right spot. Look down the hole where the dist.goes. That flat blade that goes into the bottom of your dist. should be at the 11:20 position and your dist. at #1 I agree with Mike; with a fresh WIX filter it should be a little less than 5 US qts. Quote Link to comment
The datsun kid Posted March 12, 2012 Author Report Share Posted March 12, 2012 I know but I'm on my phone it's kind of shitty lol ok I'll check where the distributer is at Quote Link to comment
The datsun kid Posted March 12, 2012 Author Report Share Posted March 12, 2012 Oh and does anyone have pic of what it's suppose to look like maby Quote Link to comment
datzenmike Posted March 14, 2012 Report Share Posted March 14, 2012 Engine at TDC on the compression stroke #1 Remove dizzy and look in the hole you should see this from the driver's fender... Quote Link to comment
The datsun kid Posted March 14, 2012 Author Report Share Posted March 14, 2012 Thanks mike I watched hainz's video and figuerd it out and so I drained the oil( new goddammit)!! Then I looked at it and it was way off. And so I dropped the oil pump down adjusted it the right way but no it doesn't run!?!? WTF! So your saying they're is a small side and a big side to the spindle head? So I'm guessing I dont have that right? Sssswweeeettttt (palm hits face) Quote Link to comment
datzenmike Posted March 14, 2012 Report Share Posted March 14, 2012 Motor must be at TDC on number one compression stroke first. Yes one side is slightly smaller and should be to the front. This off side allows the dizzy to go on in only one position. Look carefully at the posted picture you can see the left side is smaller. Quote Link to comment
The datsun kid Posted March 14, 2012 Author Report Share Posted March 14, 2012 Ok can I pull the oil pump Down without losing all my new oil I just put in? Quote Link to comment
datzenmike Posted March 15, 2012 Report Share Posted March 15, 2012 You might loose 1/4 cup so have some rags handy for the drips. Keep the oil pump vertical so it does not empty and loose it's prime. The paper gasket can be reused if you don't tear it. Quote Link to comment
The datsun kid Posted March 15, 2012 Author Report Share Posted March 15, 2012 Thanks mike don't know what I would do without you Quote Link to comment
