gypsy punk Posted March 1, 2012 Report Share Posted March 1, 2012 so a buddy of mine has a cast iron head for a l16 and i was wondering if anyone knew any more about it? he told me you could run it on propane instead of gas. but i want to know more!! Quote Link to comment
Skib Posted March 1, 2012 Report Share Posted March 1, 2012 L16P/L18P/L20P where LPG powered L motors Quote Link to comment
gypsy punk Posted March 1, 2012 Author Report Share Posted March 1, 2012 well he had gotten it off a L16 SSS that he found and didnt know much other then it could run off propane and that Nissan said it didn't even exist when he tried to find out about it. Quote Link to comment
sinner720st Posted March 1, 2012 Report Share Posted March 1, 2012 as far as an aluminum head vs an iron head for propane, i dont see where it would matter. propane burns with less intensity, giving it a higher octane rating. would also mean an aluminum head would not be harmed if running propane Quote Link to comment
Skib Posted March 1, 2012 Report Share Posted March 1, 2012 well he had gotten it off a L16 SSS that he found and didnt know much other then it could run off propane and that Nissan said it didn't even exist when he tried to find out about it. from what Iv seen the LPG motors had the same heads. its just a different carb and fuel delivery system. and there wasnt ever an L16P sss Quote Link to comment
gypsy punk Posted March 1, 2012 Author Report Share Posted March 1, 2012 hmmm well i have no clue Quote Link to comment
nismo dr Posted March 1, 2012 Report Share Posted March 1, 2012 So he had a sss forklift motor? Quote Link to comment
Skib Posted March 1, 2012 Report Share Posted March 1, 2012 oics! you should know better by now :lol: Quote Link to comment
Z chopper Posted March 1, 2012 Report Share Posted March 1, 2012 hmmmm wonder if the propane L series had flat tops to help with compression. Is the cast iron head a peanut head? Quote Link to comment
gypsy punk Posted March 1, 2012 Author Report Share Posted March 1, 2012 i will try and get some when i got up to his house again probably some time this weekend Quote Link to comment
gypsy punk Posted March 1, 2012 Author Report Share Posted March 1, 2012 hmmmm wonder if the propane L series had flat tops to help with compression. Is the cast iron head a peanut head? i think it might. and not sure on the peanut. he sasid he thinks they where using them at one point in race cars Quote Link to comment
datzenmike Posted March 1, 2012 Report Share Posted March 1, 2012 Can't see any advantage that would offset the increased weight of the iron. True SSS heads are the tits. Quote Link to comment
