dave71 Posted February 15, 2012 Report Share Posted February 15, 2012 i got a weber coming and it has electric choke and i wanna put it in my 521...has anyone else converted theirs over? ... :huh: if so what wire do i hook the choke to? Quote Link to comment
ggzilla Posted February 15, 2012 Report Share Posted February 15, 2012 Easy as 1-2-3 1. Connect the wire to the hot side of the Ballast Resistor. 2. If you are no longer running a BR, connect it to the Coil + terminal. 3. Adjust the choke! Instructions should come with the carburetor. Quote Link to comment
dave71 Posted February 15, 2012 Author Report Share Posted February 15, 2012 sweet...no istructions cause i'm getting from another member on here...thanks for the info :D Quote Link to comment
ggzilla Posted February 15, 2012 Report Share Posted February 15, 2012 Use the Datsun choke instructions from any repair manual that covers 1972 and later Datsuns. Quote Link to comment
DanielC Posted February 15, 2012 Report Share Posted February 15, 2012 A suggestion. The 521 electrical system was adequate for a stock 521, when new. It is now over 40 years old. All the accessories that are on only when the ignition is on, pull current through the original 40 year old ignition switch. Adding an electric choke adds to this load. Not much, but it is constant. I would consider adding something like this, http://www.painlesswiring.com/webcatalog/largeview.php?SearchField=70107 to add accessory fuses to the 521 stock system. That way, you could take the heater motor, and the windshield wiper electrical load out of the ignition switch, as well as the electric choke could be hooked up to one of the circuits in the kit Quote Link to comment
ggzilla Posted February 15, 2012 Report Share Posted February 15, 2012 Good idea. Even in the 620s, Datsun used a relay for the auto choke, so the choke would only be heated when the engine was running. You can buy a 620/510/610 choke relay at the wreckers and connect it to the altornater. It's not a typical 12V unit. Quote Link to comment
DanielC Posted February 15, 2012 Report Share Posted February 15, 2012 I do not have a 620, but I think they also used another relay for the heater fan motor. Quote Link to comment
mklotz70 Posted February 15, 2012 Report Share Posted February 15, 2012 Actually, the 521 already has a choke relay. It's called a heater relay. If you look at the schematic, the relay is typically at the top of the page, next to the volt reg and the auto choke connection is at the bottom, next to the coil. Physically, it's usually a loose spade connector on the firewall near the hood light switch...basically, where it would reach the wire from the choke. The relay is on the pass side of the eng compartment, but I don't know which one off hand....4 wires in a squarish connector? Quote Link to comment
ggzilla Posted February 15, 2012 Report Share Posted February 15, 2012 That's only in the 1972 521, isn't it? From 1971-back they used manual choke? The purpose of the Choke Heater relay is not to save current from going thru the switch. It is to prevent the choke from heating up when engine isn't running. For example, if you listen to the radio for a couple of minutes before starting the engine, and mistakenly put it to IGN, then the car won't start on a cold day. To prevent this scenario, the relay only powers the choke when the engine is running. The alternator provides a signal when the engine is running. It is the Neutral Sense wire (N wire). This is a weak signal so a special lower-than-12V relay is used. Quote Link to comment
mklotz70 Posted February 15, 2012 Report Share Posted February 15, 2012 Yep....you're probably right! I kinda had it in my head that my wife's '70 has electric, but I just realized that it's a weber. Most of the other 521's I had were manual choke. Good stuff gg......I keep coming up wrong posting against you LOL!!! maybe I'll just stop! :) Quote Link to comment
DanielC Posted February 15, 2012 Report Share Posted February 15, 2012 Mike, never stop posting! GGzilla, why does the power for the auto choke relay have to go through the ignition switch? If the engine is not running, Key on, the relay will not energise the choke heater, no alternator signal. Engine off, Key off, still no alternator signal, relay still not energised. Quote Link to comment
mklotz70 Posted February 15, 2012 Report Share Posted February 15, 2012 LOL! Thanks Daniel, but I didn't mean stopping totally.....just stop posting again gg.....I keep coming up wrong!! LOL I think the prob with using the ign power is that the key can be on and providing power without the engine running when you click it once to on and don't start it. If you take it from the alt, it has to be running. Quote Link to comment
ggzilla Posted February 15, 2012 Report Share Posted February 15, 2012 The power doesn't have to be through the IGN switch. But that's how Datsun did it. That wiring diagram is from the Factory Service Manual. Quote Link to comment
