Rusty Posted April 15, 2008 Report Share Posted April 15, 2008 I found this on the net, thought it was funny... Tool Dictionary DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench at the speed of light Also removes fingerprint swirls and hard-earned guitar calluses in about the time it takes you to say, "Sh*t!" ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age. PLIERS: A simple hand tool used to round off bolt heads. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Next generation Pliers. Also used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for igniting various flammable objects in your shop. Also handy for igniting the grease inside the wheel hub you want the bearing race out of. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper. EIGHT-FOOT LONG DOUGLAS FIR 2 x 4: Used for levering an automobile upward off a hydraulic jack handle. TWEEZERS: A tool for removing Douglas Fir wood splinters. PHONE: Tool for calling your neighbors to see if he has another hydraulic floor jack. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog doo off your boot. E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway. TWO-TON ENGINE HOIST: A tool for testing the tensile strength of everything you forgot to disconnect. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle. AVIATION METAL SNIPS: See hacksaw. TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. AIR COMPRESSOR: A machine that converts energy produced in a coal-burning power plant 200 miles away into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over-tightened 58 years ago by someone at ERCO and neatly rounds off their heads. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50-cent part. HOSE CUTTER: A tool used to cut hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the really expensive parts nearest the object we are trying to hit. In the South we usually say "just get a bigger hammer!" MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, rubber or plastic parts and fingers. DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling DAMMIT" at the top of your lungs. It is also the next tool that you will need. EXPLETIVE: A balm, usually applied verbally and in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight. SOUTHERN ENGINEERING: A term used to descibe the use of "baling wire" or "duct-tape" to fix a problem. Actually this one usually works Quote Link to comment
BEEBANI Posted April 15, 2008 Report Share Posted April 15, 2008 RE-POST........sorry there repeat.;) Redeye posted something similiar about a year ago. Still funny though. Quote Link to comment
fiveNdime Posted April 15, 2008 Report Share Posted April 15, 2008 RE-POST........sorry there repeat.;) Redeye posted something similiar about a year ago. Still funny though. Yeah, but how many people would have searched for that! Funny stuff, thanks :D Quote Link to comment
BEEBANI Posted April 15, 2008 Report Share Posted April 15, 2008 No, but it only took me 2 minutes to find it! http://forum.ratsun.net/showthread.php?t=287&highlight=tool Quote Link to comment
Rusty Posted April 15, 2008 Author Report Share Posted April 15, 2008 RE-POST........sorry there repeat.;) Redeye posted something similiar about a year ago. Still funny though. I said I found it on the net?... i didnt say im the guy that found somthing new that nobody has read before.:fu: and it was better than reading a new post about 620 brakes, wasnt it:lol: Quote Link to comment
BEEBANI Posted April 15, 2008 Report Share Posted April 15, 2008 or another gay ass 320! wink wink Quote Link to comment
fiveNdime Posted April 15, 2008 Report Share Posted April 15, 2008 No, but it only took me 2 minutes to find it! http://forum.ratsun.net/showthread.php?t=287&highlight=tool I'm glad you can search...."clapping" I was stating that it was funny...and that some poeple who havent been on here that long would never think about looking for that type of stuff. Quote Link to comment
BEEBANI Posted April 15, 2008 Report Share Posted April 15, 2008 I'm glad you can search...."clapping" I was stating that it was funny...and that some poeple who havent been on here that long would never think about looking for that type of stuff. Dude, ease up on the caffeine! I'm not trying to battle ya here, just showing how easy it was to find and giving everyone an opportunity to read the other post that had a lot of funny shit in it. Quote Link to comment
RB_Shaggs Posted April 15, 2008 Report Share Posted April 15, 2008 STOP FIGHTING!! i'M SERIOUS sorry on a photobucket kick today.. :lol::fu: Quote Link to comment
BEEBANI Posted April 15, 2008 Report Share Posted April 15, 2008 That Is Hilarious!!! Quote Link to comment
fiveNdime Posted April 19, 2008 Report Share Posted April 19, 2008 I have no sound on the computer right now...actually haven't for a couple weeks.....so I have learned to read lips...:lol: So that video is hopeless for me. forgot to install the driver....shoot. I haven't had caffeine for a while.....I just hate stupid sarcasm. OOh well....lets all hug....hahaha Quote Link to comment
DatDoug Posted April 19, 2008 Report Share Posted April 19, 2008 TWO-TON ENGINE HOIST: A tool for testing the tensile strength of everything you forgot to disconnect. That one is my fav:D Quote Link to comment
