carbed and turbo?
Stef
  • Replies 8
Don't look for "carbed and turbo Datsun", instead look for "turbo Datsun L20B" or whatever engine you want. Most are not turbo+EFI until you get into the stock EFI engines like KA24 or 280Z.
https://www.google.com/#hl=en&sclient=psy-ab&q=turbo+Datsun+L20B&pbx=1&oq=turbo+Datsun+L20B&aq=f&aqi=g-v1&aql=&gs_sm=e&gs_upl=3125l3125l1l3718l1l1l0l0l0l0l109l109l0.1l1l0&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=7f457db0e6809cd4&biw=1018&bih=535
It's too much of a hassle..For a Draw Through set up, You can't run a IC safely, because the fuel would pool up and you'd be driving a bomb...
http://www.the510rea...10313&start=360
On the other hand you have a blow through set up, this involves a hat or cover to enclose the carb. This is alot more work (at least in my mind) because of the but cover someone else can easily make one if they are good enough.
http://community.rat...e/page__st__260
Why not just run EFI? Making the Mani would be the hardest part, from there it's mostly sourcing a bunch of parts. Making a engine out of EFI involves lots of trial and error though, especially tuning for Boost.
http://community.rat...ct-is-finished/
You can do a carburetor and intercooler (IC) together, just do blow through. A stock Hitachi can take 5psi with a simple hat connection.
Or for the simplest install, forget the intercooler and turbo a stocker engine, and still make considerable more horsepower than stock.
Still, if you have to pay someone to do it you might as well pay for a more complicated setup so it makes the maximum HP. Then you find out you coulda done something else and made even more HP!!!
