South califas Posted January 16, 2012 Report Share Posted January 16, 2012 Well i recently lowerd loosend tha torshion bars and was wondering if i did it wrong because when im out on the road im really bouncing all over the place do i have to do other things than just loosen bolts to lower it or what? Quote Link to comment
wayno Posted January 17, 2012 Report Share Posted January 17, 2012 Well i recently lowerd loosend tha torshion bars and was wondering if i did it wrong because when im out on the road im really bouncing all over the place do i have to do other things than just loosen bolts to lower it or what? The lower you go, the worse the ride, that's life. Quote Link to comment
Zeusimo Posted January 17, 2012 Report Share Posted January 17, 2012 Raise Your Shock Towers :D Quote Link to comment
Str8_69 Posted January 17, 2012 Report Share Posted January 17, 2012 Not enough info.. How far did you lower it? Are your shocks any good, and what kind? What size wheels/tires? how close is it to the bump stops without a load on it? Oh, and where are the OICS? Quote Link to comment
albyneau Posted January 17, 2012 Report Share Posted January 17, 2012 Well i recently lowerd loosend tha torshion bars and was wondering if i did it wrong because when im out on the road im really bouncing all over the place do i have to do other things than just loosen bolts to lower it or what? The torsion bars will cause rebound no matter what's bottoming out. Your job now is to determine whether it's the bumpstops or the shocks. Bottoming out shocks is a noisy, possibly dangerous thing~ at the least you'll be ruining the shocks; if they're gas-charged you could hear a rather loud noise if they fail, and might even take out a tire or brake line in the process. This shouldn't happen under normal circumstances provided you haven't cut down/removed the bumpstop. If you have then either modify the shock mounts to compensate, or retrofit shocks are in order. When you do find some shocks that are shorter, make sure they provide at least an inch of travel beyond full bottoming~ this compensates for bumpstop compression if you hit a really bad bump, rut, or chuck hole... Peace~ Scott Quote Link to comment
South califas Posted January 17, 2012 Author Report Share Posted January 17, 2012 I had put 205/50r15 in front and in inch in a half between tire and wheelwell So that means im ganna keep boucing around? Can i put them springs that sale at pepboys that wrap around the shock will that help? Ill try to get some pics tomorrow Quote Link to comment
South califas Posted January 17, 2012 Author Report Share Posted January 17, 2012 Raise Your Shock Towers :D Grind and weld??? Quote Link to comment
Mr Raiders Posted January 17, 2012 Report Share Posted January 17, 2012 The lower you go, the worse the ride, that's life. ^^^ I concur. Quote Link to comment
