Suspension
South califas
  • Replies 7
Well i recently lowerd loosend tha torshion bars and was wondering if i did it wrong because when im out on the road im really bouncing all over the place do i have to do other things than just loosen bolts to lower it or what?
The torsion bars will cause rebound no matter what's bottoming out. Your job now is to determine whether it's the bumpstops or the shocks. Bottoming out shocks is a noisy, possibly dangerous thing~ at the least you'll be ruining the shocks; if they're gas-charged you could hear a rather loud noise if they fail, and might even take out a tire or brake line in the process. This shouldn't happen under normal circumstances provided you haven't cut down/removed the bumpstop. If you have then either modify the shock mounts to compensate, or retrofit shocks are in order. When you do find some shocks that are shorter, make sure they provide at least an inch of travel beyond full bottoming~ this compensates for bumpstop compression if you hit a really bad bump, rut, or chuck hole...
Peace~
Scott
